How to ruin OEM rims!
Old Aug 15, 2012 | 11:32 AM
soundmike's Avatar
soundmike
Originally Posted by Kidcane
^^Really? Stripping and painting, with a rattle can, while not removing the tires is the correct process? Interesting.
The stripping/sanding portion is, for what they're showing. Not removing the tire is fine. Not the best approach, but still correct.
Painting with a rattle-can, done correctly, is fine as well. And their spraying technique is far better than others i've seen. Granted, i don't see any primer and the video stops short of showing their finishing process. It could also be the paint they used does not require priming.
For a DIY, there's nothing wrong with their process.
Old Aug 15, 2012 | 11:50 AM
Gamedog's Avatar
Gamedog
Sam Rothstein
Originally Posted by soundmike
And their spraying technique is far better than others i've seen...
How many times I got to tell you stop watching Ray Charles' painting techniques on YouTube...
Old Aug 15, 2012 | 11:51 AM
soundmike's Avatar
soundmike
Old Aug 15, 2012 | 12:31 PM
Ralphie_S's Avatar
Ralphie_S
"to be continue"
Old Aug 15, 2012 | 01:13 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Because only Ray Charles could have a worse "painting technique" than they did...
Old Aug 15, 2012 | 01:39 PM
breftayka's Avatar
breftayka
Get it??? Get it???
Need a picture?
Old Aug 15, 2012 | 01:44 PM
I presumed that the coating they applied was the primer (I'm pretty sure that's not the color that they want the wheels). Especially since the video was labeled as Part 1 and it was "to be continue". And I presumed the tires weren't removed because they were going to be trashed and replaced. At any rate, I'm at a loss as to what was fundamentally wrong with their DIY as well. It would have been better to use the industrial grade paint stripper along with some heat and a scraper before sanding, but other than that they had the right idea.
For a community known for embracing Plastidip as not only acceptable but desirable as a wheel finish, I'm baffled as to why so many will hate on someone DIY refinishing wheels before even seeing the final product.
Old Aug 15, 2012 | 01:57 PM
soundmike's Avatar
soundmike
^ Thanks, BB. You worded it much better than i did.
Old Aug 15, 2012 | 02:04 PM
You're part of the problem, not the solution Plastidipper!
Old Aug 15, 2012 | 02:07 PM
Rad_Slinger's Avatar
Rad_Slinger
Lol!
Betty never disappointing with the sarcasm
Old Aug 15, 2012 | 02:40 PM
soundmike's Avatar
soundmike
Name one part of my car that has plastidip.
Black chrome is where it is baby, and i've got lots of those!
Old Aug 15, 2012 | 03:00 PM
Tazicon's Avatar
Tazicon
No kidding, well said. From a fellow Plastidip hater.
Old Aug 15, 2012 | 03:23 PM
Ralphie_S's Avatar
Ralphie_S
Have you encountered any damage from plastidip? What's up with all of the animosity? I've noticed that this website loves to strike other users down bc they dont agree with said mods. It's their own car let them do what they want to it.
I always felt like plastidip was a great solution for people who wanted to test and temp. change the look of their car.
Also before you try and spit fire my way. Just know that I honestly have no issue with the mods in the video. I just thought the "to be continue" was a great way to end the video haha. They seem extremely excited and happy with the mods. Carry on, nothing else to see here.
Old Aug 15, 2012 | 05:12 PM
  #29
soundmike's Avatar
soundmike
Honestly, i have nothing against it. I did, after all, start the fad on 'Driver for painting the grille with it. My original one was in bad shape, i used PD to get a feel for what it would look like in black. The unintended benefit is it actually kept the grille from pitting further. It even survived a front-end collision. The grille broke, yes, but no part of PD scratched off. If only our paint was as pit-proof.
I digress. It's a good temp solution, especially for certain things, but not an end-all, be-all.
I think most people hate on PD mainly because it's a $6 can of rubberized spray applied to a $30k+ vehicle.
Old Oct 2, 2012 | 02:16 AM
  #30
revealer's Avatar
revealer
what a waste of time
