TPMS lit, not sure why
Old Jun 6, 2012 | 11:13 AM
tattoo400's Avatar
tattoo400
Okay the TPMS (low tire pressure) indicator came on this morning but the pressure's are all the same as when I got the car. They are all at or right next to 32 PSI. I have aftermarket 20" Boss wheels on it and again.....the light has never came on until now....any idea's on wtf is going on? I expect it to not come on later as the temps get higher....but still please help
Old Jun 6, 2012 | 11:15 AM
Modme's Avatar
Modme
Did it flash for 30 seconds and then stay lit? Or did it just come on without flashing?
Old Jun 6, 2012 | 11:16 AM
DashKid's Avatar
DashKid
Wait 32? That's kinda low. I have mine at 35 front 36 rear.
Try to put more air to like 34 or 35 and see if it goes away. If not than it could possibly be a bad senor.
Old Jun 6, 2012 | 11:17 AM
CEELOSG37S's Avatar
CEELOSG37S
LA G Club
Did you reset the TPMS after the install of the wheels?
Old Jun 6, 2012 | 11:19 AM
tattoo400's Avatar
tattoo400
No, it comes on solid right off the bat....I assume that means there is a malfunction with the system? Not sure how to remedy this......
Old Jun 6, 2012 | 11:20 AM
tattoo400's Avatar
tattoo400
Ah, I see.....I will fill them a little more and see if that gets rid of it......if not, then that means the sensor has a problem. Thanks!
Old Jun 6, 2012 | 11:30 AM
tattoo400's Avatar
tattoo400
How exactly do you reset it? It was fine when I got the car about a month ago and the pressure's are still the same so I don't know....
Old Jun 6, 2012 | 11:34 AM
Modme's Avatar
Modme
Sounds like a low pressure problem. If you turn on the car and the TPMS light blinks for 30 seconds and then stay on, it is a malfunction.
If you turn on the car and the light stays lit without blinking, it is a low pressure.
Double check your tire pressure. Usually the light doesnt turn on until < 27psi.
Old Jun 6, 2012 | 11:47 AM
tattoo400's Avatar
tattoo400
Okay, that's what I was thinking. I will put some more air in today. Thanks!
Old Jun 6, 2012 | 12:42 PM
ZOSTER33's Avatar
ZOSTER33
Put more air and drive for about 1/2 mile and the light should turn off.
Old Jun 6, 2012 | 02:03 PM
eVitO's Avatar
eVitO
Is there any way to turn off the light without disconnecting it from the OBDII port?
Old Jun 6, 2012 | 02:35 PM
Topher9425's Avatar
Topher9425
Any reputable tire shop should be able to reset it for you.....i know my boys at discount tire have a machine that resets each TMPS then plugs into your OBDII
Old Jun 6, 2012 | 03:25 PM
Envy_My_G's Avatar
Envy_My_G
how can i remove my TPMS out of my old set of tires and place them into my new ones? my tire pressure light is always on and it ****'s me off.
Old Jun 6, 2012 | 03:48 PM
Topher9425's Avatar
Topher9425
you have to have your old sensors swapped into your new wheels.....which will take the shop dismounting/remounting your tires.
Old Jun 6, 2012 | 04:40 PM
ZOSTER33's Avatar
ZOSTER33
If the shop knows what the are doing there is no need to remove the entire tire to remove the sensor.
