larger tire with spacers question
Old Mar 13, 2012 | 02:02 PM
snaik69's Avatar
snaik69
Just want to confirm....i have 20mm spacers all around with stock wheels and an eibach drop....correct me if im wrong but going wider (275/35/19 and 245/40/19) will not affect anything ie; rubbing due to spacers?
much appreciated!
Old Mar 13, 2012 | 02:11 PM
Sunny G's Avatar
Sunny G
I don't think it will affect anything you may have rubbing in the back but it's nothing a little heat gun and a roller won't cure
Old Mar 13, 2012 | 02:18 PM
GET_SOME's Avatar
GET_SOME
if you rub in the back all you will need to do is shave the bumper bracket. its not hard to do yourself if you have a dremel. I am dropped on tein s-techs right now with 20 mm spacers and i dont rub.
Old Mar 14, 2012 | 10:28 AM
snaik69's Avatar
snaik69
thanks guys....
Old Mar 14, 2012 | 10:47 AM
LegitMW's Avatar
LegitMW
I doubt you'll run cause that isn't too aggresive. You also have to factor in that the stock tire profiles are 45F/40R. So if you're going 35/30 I think it'll be fine.
news1213
Dec 16, 2015 11:06 AM
connoisseurr
NorthEast
Aug 29, 2015 08:00 AM
gcruzjr78
Aug 18, 2015 10:15 AM
