Help Offsets and Tires Specs Decision
Old Feb 3, 2012 | 02:59 PM
frty9rsfn's Avatar
frty9rsfn
hey offset and tires gurus, i need your input/help on deciding which offsets and tires sizes to go with before pulling the trigger on a 08 g37s ... dont want to run much more negative camber (give or take) and stretch tires... front and rear cambers are -1.25 and -1.5 respectively (on spc arms) and lowered on Tein Flex... I do know i will have to shave my rear bumper bracket to make this work...
i want to make the front and rear wheels flush evenly without any issues of rubbing... so here we go...
im set on the rear offset with 19x10.5 + 30... but have the option of going with 19x10.5 + 22... but 19x10.5 + 30 it is...
the front options are as follows:
(1) 19x9.5 + 22
(2) 19x9.5 + 30
(3) 19x9.5 + 38
i think the 19x9.5 + 22 and 19x10.5 + 30 would sit flush evenly all the way across... not sure if the front would rub though... what are your takes?? please shine in...
i also want to run 245 and 275 front and rear respectively... please help with the specs... help me put this together guys...
thanks for you input and for all in this board...!!!
frty9rsfn
Old Feb 3, 2012 | 03:24 PM
fairladyz34's Avatar
fairladyz34
option 2 for the fronts. you wont rub
Old Feb 3, 2012 | 06:40 PM
1cleanG's Avatar
1cleanG
NextLevel Performance
Originally Posted by fairladyz34
option 2 for the fronts. You wont rub
+1 to option #2!!!!!!!! If you don't want negative camber, and zero rubbing, +30 in the front would be a good choice.
Old Feb 3, 2012 | 09:31 PM
frty9rsfn's Avatar
frty9rsfn
if i went with option one, 9.5 + 22, how much negative camber are we talking about??
Old Feb 3, 2012 | 09:40 PM
frty9rsfn's Avatar
frty9rsfn
im already running -1.25... where would i rub exactly and how much... (on turns, exesive speeds..etc)? would i not be able to push it??? would i sit flush?
Old Feb 4, 2012 | 02:10 PM
frty9rsfn's Avatar
frty9rsfn
what tires specs do u guys recommend too??
Old Feb 6, 2012 | 10:07 PM
frty9rsfn's Avatar
frty9rsfn
Bump to the top... help guys... cant make up my mind... +22 or +30 on 19x9.5 on the fronts... tough choice...
uzbekuz
Sep 8, 2015 05:54 PM
footballmania32
Sep 4, 2015 03:06 PM
footballmania32
Sep 4, 2015 02:17 PM
