20" Wheels on stock suspension...
Old Jan 16, 2012 | 07:16 PM
Kuro's Avatar
Kuro
Coilovers is the way to go
Old Jan 16, 2012 | 07:27 PM
Jadex153's Avatar
Jadex153
Problem with coilovers is every time you hit a pot hole, it'll throw you pretty bad.
Old Jan 16, 2012 | 07:28 PM
G37S-OONER's Avatar
G37S-OONER
Well what coilovers would you recommend?
Can you also explain coilovers vs springs, cost and difference.
Thanks in advance.
Seriously looking into CV2s with a drop, "budget is about $3,500 ish"
Old Jan 16, 2012 | 07:49 PM
soolman32's Avatar
soolman32
My G in its early days. a drop is really a must
Old Jan 16, 2012 | 08:09 PM
Kuro's Avatar
Kuro
Brand new coils cost 1000-2000ish
Brand new spring cost 150-250ish
Old Jan 16, 2012 | 08:14 PM
Skyline6mt's Avatar
Skyline6mt
go with coils if you can if not swift or eibach springs are the way to go
Old Jan 16, 2012 | 08:17 PM
Kuro's Avatar
Kuro
https://www.myg37.com/forums/brakes-...pring-kit.html
https://www.myg37.com/forums/g37-cou...coilovers.html
https://www.myg37.com/forums/brakes-...coilovers.html
Old Feb 13, 2012 | 04:09 PM
hdizzle117's Avatar
hdizzle117
Heres my G37s on cv2s without the drop
here it is with the drop
Hope that helps!
Old Feb 13, 2012 | 05:54 PM
terrycs's Avatar
terrycs
Also keep in mind wheel offset should be determined by whether or not the car is dropped. The wheels move in-board as the car is lowered.
So if you buy wheels with offsets for your G with no drop, the next buyer will most likely need spacers if his car is dropped.
Old Feb 13, 2012 | 05:57 PM
P Casey's Avatar
P Casey
A drop is a must..if you get aftermarket wheels
Old Feb 13, 2012 | 06:34 PM
TVPostSound's Avatar
TVPostSound
is dropped.
Only if you choose tho not have it realigned.
Old Feb 14, 2012 | 03:12 AM
wagonmaster69's Avatar
wagonmaster69
This how we bout ours with 20" nichie Venice rims.
<a href="http://s344.photobucket.com/albums/p351/wagonmaster69/?action=view&amp;current=IMG_0936.jpg" target="_blank"><img src="http://i344.photobucket.com/albums/p351/wagonmaster69/IMG_0936.jpg" border="0" alt="Photobucket"></a>
Old Feb 14, 2012 | 03:36 AM
wagonmaster69
And the suspension is stock.
I know I should lower it a bit.
<a href="http://s344.photobucket.com/albums/p351/wagonmaster69/?action=view&amp;current=IMG_0937.jpg" target="_blank"><img src="http://i344.photobucket.com/albums/p351/wagonmaster69/IMG_0937.jpg" border="0" alt="Photobucket"></a>
Old Feb 14, 2012 | 03:00 PM
  #29
noloveg37's Avatar
noloveg37
stock and yes i need to drop it and fast!
Old Feb 16, 2012 | 04:15 PM
  #30
Fresh Mobile's Avatar
Fresh Mobile
I have eibachs with 20s and it’s no hydraulic ride. It’s 10x better than stock and improved handling. Spring is a little stiff, but it’s exactly how I want it. You might wanna get the F+B SPC camber kit as well for better tire life and proper alignment. Coils as mention above gives you more flexibility for height adjustment where spring is set at one height.
