20's on an '09 Sedan
Old Oct 26, 2011 | 01:12 PM
R3diK3r0u5's Avatar
R3diK3r0u5
am i going to be the one to say it? one casual look through the "new posts" section will show you plenty of G's rocking 20's. No need to even use the search function. completely useless thread.
Definitely don't raise it and in fact, it will probably look worse than your stocks until you lower it. As others have said, def try to retain the original diameter of the wheel/tire combo to ensure your speedo isn't off.
Here is a helpful website for that
Old Oct 26, 2011 | 07:56 PM
DirtyJacket's Avatar
DirtyJacket
Are you kidding me?
I was simply asking if it required ANY suspension work/raise to accomodate 20s. WTF do pictures of g37s with 20s do for me? I have no clue if they've required suspension work or not. Youre a douche.
Old Oct 27, 2011 | 01:09 AM
R3diK3r0u5's Avatar
R3diK3r0u5
take it easy there. just saying if you browsed a little bit you answers would have been found easily. thats basically the most common discussion, you'll understand once you've been here a bit.
and i was still trying to be helpful man, did you check out that webpage? that was how i picked out my tires.
Old Nov 2, 2011 | 05:24 PM
botlfed98's Avatar
botlfed98
those gotta be like 24"s atleast on that coupe! that looks horrible
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
aktif8
May 23, 2016 11:56 AM
johnadlertech
Sep 14, 2015 12:22 PM
johnadlertech
Sep 14, 2015 12:18 PM
m3clubracer
Sep 13, 2015 09:01 AM
