Tpms 315 mhz
Old Oct 7, 2011 | 03:49 PM
Ibanez540r's Avatar
Ibanez540r
Tpms 315 mhz
So, I'm curious what variances TPMS sensors have from manufacturer to manufacturer (infiniti, dodge, etc.)? I understand there are different frequencies, believe the infiniti is 315MHZ, but what keeps a certain 315mhz sensor from working with another 315mhz car?
Old Oct 8, 2011 | 10:57 PM
Ibanez540r's Avatar
Ibanez540r
I guess no one knows???
Old Oct 11, 2011 | 04:41 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
The oem ones are 315mhz. Even though others will be same frequency, they are programmed differently for each car. If every car had the same brain box they might be universal.
Old Oct 15, 2011 | 02:16 PM
TVPostSound's Avatar
TVPostSound
Also the transmitter in a TPMS is very weak. The other car would have to be rubbing you to even mess with your readings.
Old Oct 15, 2011 | 04:46 PM
Ibanez540r's Avatar
Ibanez540r
Can they be re-programmed to the infiniti?
Old Oct 15, 2011 | 04:48 PM
Ibanez540r's Avatar
Ibanez540r
That's not the issue. I bought a set of wheels that have 315mhz tpms installed. Trying to find out if they will work.
Wheels yet to be installed..
Old Oct 15, 2011 | 04:50 PM
JSolo's Avatar
JSolo
Just say no!!!!!
There's handshaking and authentication keys involved. I'm sure it's more complicated than this, but that's the general idea.
On a previous bike, it had a sort of smart key system. No fob, no start. On more than one occasion, when filling up at mobil stations that supported speedpass, I had difficulty if the bike was too close to the pump. Had to roll it back or forward away from the antenna, then it would recognize the fob - google KIPASS if you want more info.
Old Oct 16, 2011 | 01:27 AM
cy7878's Avatar
cy7878
Just take them to any tire shop. For $20 they will try to synch the sensors and you will find out before swapping them out.
Old Oct 17, 2011 | 10:20 PM
cvipgo's Avatar
cvipgo
If you have the tpms sensors on your car's existing wheels then you can copy the sensor ids to new set of TPSMs - need to have TPMS id reader/copy programming tool. Once ids have been transferred then the wheels with new sensors will work fine- that's what the tire shops do.
Old Oct 17, 2011 | 11:59 PM
Ibanez540r's Avatar
Ibanez540r
Thank you. Nice clear answer.
Old Oct 18, 2011 | 12:58 PM
HRDROKN's Avatar
HRDROKN
Would this be the same for aftermarket TPMS... such as those produced by Dorman?
Old Oct 18, 2011 | 02:24 PM
cvipgo's Avatar
cvipgo
yes.
04G35NYC
Dec 24, 2015 01:00 AM
Depravity
Oct 16, 2015 01:37 PM
jgronline
Sep 21, 2015 08:44 PM
JG_G37
Sep 19, 2015 09:07 PM
Thirty_Seven
Sep 18, 2015 11:34 PM
