Help with offset
Aug 31, 2011 | 11:43 AM
Help with offset
Will a 19x9.5 19x.10.5 +16 all around work without doing body work? Or is a 19x9.5 19x10 or 10.5 +25 all around better?
Aug 31, 2011 | 12:18 PM
Aug 31, 2011 | 12:19 PM
what is the most agressive i can go without doing fender work? im also going to run a 225/45/19 and a 245/40/19 on them.
Aug 31, 2011 | 12:45 PM
damn that's some meaty tires! +25 should work with those tires
Aug 31, 2011 | 01:10 PM
xlack is correct.
Those sidewalls you mentioned would be too tall and would rub with either offset you posted if you are dropped at all.
Aug 31, 2011 | 01:16 PM
Wished they made 225-45 in 20". I would get those in a heart beat
Don't forget you lose a little sidewall when you're putting a smaller tire on a wider rim
Aug 31, 2011 | 01:21 PM
Aug 31, 2011 | 01:22 PM
Look op don't go bigger than a 35 sidewall
Aug 31, 2011 | 02:01 PM
Quote:
Originally Posted by
Doggy
LOL
Aug 31, 2011 | 04:19 PM
So what size tire should i rock with that setup?
Sep 1, 2011 | 11:05 AM
Tire Size
19x9.5 +22 19x10.0 +22 What size tire should be appropriate for that setup? I have a set of 225/45/19 & 245/40/19. The rears will be to meaty right?
Sep 1, 2011 | 12:15 PM
Threads merged since they are pretty much touching on the same subject...
A 35/30 sidewall (respectively) would probably work best, those offsets are a bit on the aggressive side.
Sep 1, 2011 | 02:26 PM
Yeah i wanted them pretty agressive. So a 245/30 or a 235/30?
Sep 1, 2011 | 02:57 PM
I'm running +18 9.5 front and +23 10.5 rear without body work, my tires are 235/35 front 245/35 rear
Sep 1, 2011 | 04:42 PM
NoirG
I just checked your setup your car is sick..but now i wish i went a little more agressive with the wheels. Like a +16 all around.
