Help Taking the plunge tomorrow :( NEED HELP! +35 NOT WORKING!
Evening all,
Could use some help please! I'm trying to fit 19x9.5 +35 in the rears. We test fitted today (unfortunately the lug nuts didn't fit). After taking an initial peak, I'm very concerned that they won't fit. They stuck out a good inch from the wheel well (fender line). They're a set of Volk TE37s. Fronts are also +35 but 19 x 8.5. I've been looking around and I'm seeing people with 19x10.5/10 doing +22 - perfect fitment. We unfortunately didn't get a chance to drop the car because of the lug nut issue (off a TL-S - his lugs wouldn't squeeze over my studs). We're planning on going to Les Schwabb tomorrow to see if we can get a set of lugs + have them put them on.
Would greatly appreciate your advice prior! THANKS GUYS!
I think you should be fine, especially once you lower the car. But 19x10.5 +22 on a sedan is not perfect by any means. On a coupe its pretty perfect but a sedan its WAY aggressive
i'll give it a shot. as i mentioned, we couldn't drop the car on the ground (lugs weren't fitting). i did my research prior - i was certain they would work. it was only after seeing the wheels sticking out ~an inch that i became nervous. we'll see tomorrow. thanks VERY much for ALL your input guys
