Needing some help on OD for AWD coupe
Old May 16, 2011 | 08:51 PM
WhiteLightning's Avatar
WhiteLightning
Exclamation Needing some help on OD for AWD coupe
ok so i dont mean to repost or anything but i've come down to some much wanted specs for wheels and I just wanted to know if this would work on an awd coupe
offset would be F +20 R +25
F 235/30/20 R 255/30/20
if not, please could someone give me some sort of formula for calculating a proper OD for staggered wheels on an X coupe
ive also seen offset F 32 and R 42 which looks very nice as well
Old May 16, 2011 | 09:36 PM
WhiteLightning
bump for some guidance!
Old May 16, 2011 | 11:04 PM
MoonliteMadness's Avatar
MoonliteMadness
For AWD, the diameter must be the same on all 4 wheels. Check out this web site to calculate your diameter.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old May 16, 2011 | 11:13 PM
simpson_G37X's Avatar
simpson_G37X
no it doesnt need to be exactly the same. as long as your less than 3% your fine.
245/35/20 275/30/20 is 1.1%
245/35/20 285/30/20 is 0.1%
im getting the first combo and will update when they arrive. if it doesnt work out then il get the 285 but im not worried about it.
Old May 16, 2011 | 11:20 PM
WhiteLightning
Well i hope it works out fine im sure it will look great and the fact that ur going with 275 will show off the wheel a bit more right ? but with your help i know now that this will totally work. and just to make certain with you going with 275 that would mean that the rear tire is slightly not as tall as the front one?
Old May 16, 2011 | 11:27 PM
simpson_G37X
no problem. im getting the 275 because i was worried about rubbing with the 30 offset. if i have an extra 5mm of space then i will get the 285's.
the height difference is minimal between the 245 and 275, resulting in the 1.1% difference in circumference. theres a guy running over 3% on his FX with no problems. some say 3% some say 5%, stay on the safe side lol theres plenty of options
Old May 16, 2011 | 11:46 PM
OB G's Avatar
OB G
This should help:
http://victorylanegarage.com/downloa...oze-041911.pdf
Simpson, I think you calculated the second OD incorrectly...
To calculate the overall difference between the two tires, take the larger OD and subtract it by the smaller OD and then divide by the larger OD. ie. for 245/35-20 the OD is 26.8 and for 285/30-20 the OD 26.7. Therefore we have (26.8-26.7)/26.8 = 0.37% difference in the two ODs.
GL with whatever tire you choose =D
Old May 16, 2011 | 11:51 PM
simpson_G37X
thats the table that i used . you can also get diameter of different rim diameters by changing the 20 in the script
Old May 17, 2011 | 07:27 PM
WhiteLightning
Originally Posted by mikeli688
This should help:
now im confused... how does that chart work? and will 285/30/20 245/35/20 work like previously stated?
Old May 19, 2011 | 10:06 AM
Fico's Avatar
Fico
Not to thread jack, but it may be easyer then starting a whole new thread...
how do you guys feel about this set up on a Gcoupe AWD
255/40/19 F +30 8in wide rim
285/35/19 R +25 9.5in wide rim
id only have a mild drop at the very most, Eibach prokit (1.9/1.2 if i remember correctly)
Old May 19, 2011 | 10:54 AM
simpson_G37X
as far as circumference is concerned, your all good. that setup is 0.37% which is nothing
depends on the offsets if it will rub or not though
Old May 19, 2011 | 10:59 AM
Fico's Avatar
Fico
yeah thats what i was thinking, i hate not being able to try them on... you dont buy shoes with out trying them on and rims are a few bucks more (><')
Old May 19, 2011 | 01:25 PM
OB G's Avatar
OB G
Fico, depends on the wheel, but I don't think you should have any problem running that setup, . 8" ET30 9.5 ET25 should clear fine. But why are you running the higher offset in the front?
Old May 19, 2011 | 02:43 PM
Fico's Avatar
Fico
i got my numbers mixed up lol, swapping tabs><
now i just have to check what offsets i can actualy get the rims in.... thanks for the help guys
Old May 19, 2011 | 02:55 PM
simpson_G37X
the wheels i got are 25/30 offsets. il let you know how it works out and if you would be able to run those tires. im going 20" but the overall tire height is pretty close
