Spacers on stock 19inch wheel setup?
Old May 9, 2011 | 12:40 PM
breftayka's Avatar
breftayka
Originally Posted by 08slate08
problem with non oem tire sizes is you cant rotate them not to mention these tires are madddd expensive
Right, but unless you have AWD, the front wheels are 8.5 " wide and the rear wheels are 9 " wide. Which is why we have different tire sizes on our stock wheels. 225 on the front 245 on the rear I think.
Originally Posted by Gee37S
Yeah too much tire would be bad, but I don't think 275 is overkill. People run 285,295 and even 305 on the G.
Yeah, but they are running those on 10.5 and 11 inch wide wheels.
Old May 9, 2011 | 12:51 PM
Gee37S's Avatar
Gee37S
Agreed, but a 275 on a 10.5 is stretched... I'll snap a pic later so you can have a look, it's nice a flush with the rim and really makes the car handle a lot better.
Old May 9, 2011 | 01:00 PM
MurderedG37s's Avatar
MurderedG37s
Stock tire size?
yeah, stock tire sizes
Old May 9, 2011 | 01:34 PM
Unique Bliss's Avatar
Unique Bliss
I am not trying to thread jack either, but I am currently riding on 19" sport rims with stock tires on my 2008 G37S coupe. I just purchased some BC adjustable coilovers and a rear SPC camber kit. I am planning on keeping my oem wheels for awhile. What size spacers would be best to have that "flush" look? I am also weary of any extra vibration caused by the spacers being added on...
I figure this might help even the original post at this point...
Thanks.
Old May 9, 2011 | 01:39 PM
Gee37S's Avatar
Gee37S
Depends how low you want to go. The lower you go, the larger the spacer you'll need to be flush... If you want to lower it about one inch then 20mm all around should be fine. If you plan on goig even lower, 25mm should do the trick...
Old May 9, 2011 | 01:43 PM
Unique Bliss
I'm not planning on slamming the car, but I my goal is to get rid of the wheel gap in front and back. What kind/type/brand of spacers are necessary if I go with 20mm or 25mm?
Thanks
Old May 9, 2011 | 02:10 PM
Gee37S's Avatar
Gee37S
Most popular choice seems to be the H&R. Some people get vibrations, others don't. It all comes down to proper installation.
Old May 9, 2011 | 03:35 PM
breftayka's Avatar
breftayka
Eibach spacers here. No problems at all.
Old May 9, 2011 | 04:20 PM
Unique Bliss
Thanks for the input. What size spacers are you using?
Old May 9, 2011 | 05:16 PM
JohnnysG's Avatar
JohnnysG
Honestly, if your dropping $110 anyways on some spacers, I would just buy some Project Kic Spacers and get the Hub Centric Ring for them just because of better reviews from them. I had Ichiba V2's and it gave me vibrations
Old May 10, 2011 | 12:29 AM
Unique Bliss
So I am gathering that 15mm H&R spacers would be fine with the stock 19's lowered on BC coilovers...? Would 20mm be pushing it?
Thanks
Intake
Dec 25, 2015 09:38 PM
news1213
Dec 16, 2015 11:06 AM
dAgent
Dec 1, 2015 09:03 PM
james6980
Oct 9, 2015 01:28 PM
connoisseurr
Sep 20, 2015 04:14 PM
