Another I need help with size and offset on the G37x Sedan
Old Apr 7, 2011 | 01:53 PM
TeRRoRiFiC35's Avatar
TeRRoRiFiC35
Alright, I'm planning on buying a set of the VIP Modular VXS110 for my '11 G37x Sedan. I have read the threads about tire sizes needing to be similar in order to now throw off the AWD. That is fine, I understand that. Coming from civics this is a new beast I am still learning when it comes to staggered fitments. Currently I am dropping the car on the G35x Sedan Eibach springs but will be swapping those out of the JIC Magic coilovers for the G37x sedans when they come out this summer(i refuse to purchase BC Racing due to hating them on my civic). I also plan to swap out the oem brakes that come with the sedans for the Akebono brakes. Now my questions come are for size and offset.
1) Will 19x9.5 +20 and 19x10.5 +25 sit FLUSH. Don't care of I have to run negative camber (no more than 3 degrees, will swap out camber arms if needed).
2) Will this same setup in a 20 work?
3) If either of these work, what tire sizes would you recommend(dont care if I have to stretch)? I just dont want to be sitting on rubberbands on NJ roads since this state refuses to upkeep them and I DD this car.
4) For winter purposes with the Akebono's, will 18x9.5 +12 be too much (looking at VorrsToen es2.2.1)? I think it will be, just checking. Also looking into Rotiform BLQ's.
I ask all this because the guy at VIP Modular asked me to call and I dont want to be thinking of crazy offsets that are going to be making me run 5 degrees of camber or something crazy like having to cut the fender and go with a metal widebody in the rear.
Here is also pics of the wheels just for reference:
Thanks in advance to anyone that helps.
Also had a chop done with one of Igors photo's
Old Apr 7, 2011 | 01:58 PM
Doggy's Avatar
Doggy
You'll be fine with those offsets on a 19 inch wheel
Old Apr 17, 2011 | 12:29 AM
TeRRoRiFiC35
anyone else wanna chime in?
G37xhibeet
Nov 15, 2016 09:29 AM
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
drewfinity
Aug 20, 2015 08:17 PM
DevinKoolie
Aug 11, 2015 06:47 PM
pledes23
Aug 11, 2015 10:54 AM
