Vossen CV1's on G37x ??? Help!
Old Apr 2, 2011 | 05:12 PM
DoubleD's Avatar
DoubleD
Love the Vossen CV1's - want to put them on my G37x. Has anyone done this yet? Will be getting the Eibach PK for the X put on in 2 weeks..
Do you get to select the offset you want or is there a standard for all CV1's? What offset will work best with the eibach g37x springs? Can I add spacers?
The shop I got the quote at suggested 245/35/20 and 275/30/20 Toyo Proxes T1-S tires.. Will this work? My understanding is that with the awd, rotating diameter has to be within 3% or so... So do I need to go 30/30 or can I go 35/30?
Would appreciate any help/insight!!
Old Apr 2, 2011 | 06:00 PM
Steveo47's Avatar
Steveo47
withing 5%, as long at its withing 5% your good, you can have your tires as wide as you like
Old Apr 2, 2011 | 06:03 PM
P Casey's Avatar
P Casey
can you all stagger with awd?
Old Apr 2, 2011 | 06:17 PM
BooSa37's Avatar
BooSa37
There are no 30/30 nor 35/30 offsets on CV1. Vossen only offers 32/45 (I believe) and 20/25. I think you will have to go with 32/45 your tires can be 245 front 285 rear. Hope it helps
Old Apr 6, 2011 | 07:08 PM
5gluder's Avatar
5gluder
Is it possible to run 20/25 offset on a G37x?
Thanks
Old Apr 16, 2011 | 11:03 AM
simpson_G37X's Avatar
simpson_G37X
im pretty sure he was talking about tire height....not offsets when he said 30/30 and 30/35
id like to know the answer to this too
Old Apr 16, 2011 | 11:12 AM
BooSa37's Avatar
BooSa37
If it's tire, you can either do 30/30 (I'm running that with my cv1) or 30/35
Old Apr 16, 2011 | 11:18 AM
P Casey's Avatar
P Casey
So off topic, can you run a staggard set up with an awd ?? I just remeber someone having trouble with it in the past.
Old Apr 16, 2011 | 11:28 AM
simpson_G37X
i think as long as the overall rolling diameter is within 5% your ok
i just did a quick calculation and i think a 30/35 setup on a 20 wheel is +- 1.7% ish
Old Apr 16, 2011 | 11:30 AM
P Casey's Avatar
P Casey
hmmmm... gotcha.
Old Apr 16, 2011 | 11:57 AM
simpson_G37X
id like it if someone could confirm the 5% rule though lol
Old Apr 16, 2011 | 12:06 PM
shumby's Avatar
shumby
3% is the rule. check any tire websit as well as ask most tire stores. However 5% is ok I run 5% off on my FX.
Old Apr 27, 2011 | 06:56 AM
G37xs21's Avatar
G37xs21
what do the offsets 32/45 & 20/25 actually mean? is it how flush they are or something else? def a newb when it comes to wheels. also what is the tpms or is it tmps? im loiking to buy cv1 for my xs sedan.
Old Apr 27, 2011 | 07:47 AM
G37S_Sedan2010's Avatar
G37S_Sedan2010
TPMS = Tire Pressure Monitor Sensor
Old Apr 27, 2011 | 12:30 PM
Mike@Vossen's Avatar
Mike@Vossen
SUPPORT AUTHENTICITY!
Seems like most questions were already answered. Let me know if there is anything else I can do for you. Thanks guys!
