Wheel lock questions.
i guess im the only one with the locks that your asking about. You can't put a socket/hammer to take these off. because the magnetic lock on the outside has a spring on the inside so it will just bounce back and it'll spin all day until the magnetic lock is opened. Then they have proprietary locks underneath the magnetic one.
That lock is not like the "infiniti oem locks" that every shop has a key to. Im glad i bought these, expensive yes but im happy with them. And i have a full set of formula locks so if they got these 4 off they'd still need another 16 sockets and a long time hammering to get my wheels
Where did you get these? I was planning on getting them but the price was around 130-140 shipped to the US
Does anyone know if these will fit on the oem 19s?
RAYS DURA RACING LUG NUTS INFINITI G37/NISSAN 350Z - eBay (item 180572351275 end time Apr-07-11 15:03:58 PDT)
Update:
Got the studs fixed....they said the damage wasnt as bad as I thought and all they had to do was just rethread the studs...i took that route cost me 50$ + tip and 20 minutes of my time....should be good now
Ah well at least you're good to go now. Congrats! Be careful now and dont force the square block into the round hole. :P
Honda's threading is 1.5
Nissan's threading is 1.25
There's different ends to lugnuts. "Acorn" ones are the most common OEM lugs, while many aftermarket wheels and lugs are "conical". OEM Infiniti lugs are neither.
All specs have to match, not just one or two, or they won't properly hold the wheel on.
LOL @ These guys making a killing. A die for that stud would've been about $10. I suppose they did have to take each wheel off and back on, so $50 isn't the worst deal ever.
lol thanks...all i need to do now is put the infiniti oem locks on today after work and ill be good to go...got tints done last night too...15% "Llumar" all around will post pics tonight
Our wheels are some kind of aweird hybrid.
They are like cones, but its not the cone that holds the wheel, its the washer which is more like a mag lug.
OEM wheel locks are McGuard.
@ Brooklynstar, i am glad you got that worked out. It could have been worse.
Ya sounds about right i got them from nengun or something like that. Only place i could find that sells them. But knowing they're that expensive kinda gave me a piece of mind that not many people have the keys
true that. I might consider ordering them from the same place. Do these fit OEM rims fine? Do you happen to know if they fit the OEM sport rims?
I bought the OEM MCguard wheel locks, and put them on, they seem to be good enough protection unless the thief has my key. Banging a socket might prove difficult since the key in the inner part. I think the socket wouldn't be able to grip the locks rounded shell to apply enough torque to remove the lock. Either way I hope it makes most thieves say "its not worth my time."
