Anyone here running staggered rims with AWD?
Old Mar 19, 2011 | 01:07 AM
MoonliteMadness's Avatar
MoonliteMadness
Anyone here running staggered rim sizes on a G37x? I was wondering if there are any issues or problems?
Thank you
Old Mar 19, 2011 | 01:16 AM
simpson_G37X's Avatar
simpson_G37X
yeah several people are. from what ive heard, as long as the overall height is VERY close to the same, then you should be ok
Old Mar 19, 2011 | 07:13 AM
Breitling65's Avatar
Breitling65
I wouldn't suggest this. It is clearly prohibited by any car manufacturer.
Old Mar 19, 2011 | 10:56 AM
Djfarhan's Avatar
Djfarhan
please do not double post, i have responded here: https://www.myg37.com/forums/g37-sed...-with-awd.html
Old Mar 19, 2011 | 02:03 PM
Steveo47's Avatar
Steveo47
Yes you can. Stagger is fine. Rolling diameter o the wheels need to be within 5% of eachother.
Old Mar 21, 2011 | 10:40 AM
csnpsu's Avatar
csnpsu
It is fine, do not worry. The width can be staggered but the rolling circumference cannot be different.
S wheels are staggered that way, I have them on my 09 X and they are fine.
Old Mar 21, 2011 | 10:45 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
yes, Triple_X is running staggered I know for sure, I'm certian others are as well with no problems
blatantly wrong. check your facts
Old Mar 21, 2011 | 07:18 PM
MoonliteMadness
I researched this topic extensively and spoke with reps at three Infiniti dealers, as well as a rep at Tire Rack. As someone previously stated, the width of the tire doesn't matter, it's the diameter of the wheels that matters. If the diameter of each wheel is not the same (or very close to being the same) the AWD will engage. There is a tolerance threshold (some say 3%, while others say 5%) that you must be below. Here's a cool website where you can check the diameter of wheels based on different tire sizes: Custom rims, wheel tire packages for your ride - RIMSnTIRES.com After you enter the specs, scroll down to the tire diameter and it will show you the difference in diameter in inches, mm, and as a percent. By the way, I never knew that despite the rim size and side wall height being the same, the width of a tire will effect the diameter.
Old May 15, 2011 | 02:01 PM
coolraz's Avatar
coolraz
I am running vossen cv-2s 10.5 in the back. Only been a few hunted miles but no problems so far. DO your research with the tire sizing calculator t make sure dolly diameter will be same. My setup is around 0.37% diff only.
I'll let you know how it goes in 5000 miles tho : )
Old May 15, 2011 | 02:22 PM
WhiteLightning's Avatar
WhiteLightning
coolraz whats your offsets and tire sizes?
Old May 16, 2011 | 02:41 PM
coolraz's Avatar
coolraz
Front:
20x9.0 in 245/35ZR -20 (hankook v12) +32 offset
Rear
20x10.5 in 285/30ZR -20 +45 offset
p.s I am not sure about the offset I have to double check but that is the "conservative" offset I believe out of the ones that Jav posted up when he introduced CV-2s. You can see in the pic the front wheel really is not concave by much adn the back wheel has some, but not as much as some others.
Attached Thumbnails Anyone here running staggered rims with AWD?-user335151_pic10590_1305512877.jpg
Old May 16, 2011 | 05:27 PM
WhiteLightning
Front:
Rear
PERFECT PERFECT PERFECT!!!! you just sold me on staggered fitment....
the conservative look is cool with me!... and i it works with AWD double bonus points LOVE IT! any more pics
Old May 16, 2011 | 07:02 PM
coolraz's Avatar
coolraz
All I got for now is crappy cell phone pics (this setup is NEW!) but here goes. Im gonna try to get some nice ones at the next NGC meet, they got some really talented ppl taking pics.
Attached Thumbnails Anyone here running staggered rims with AWD?-img_0203.jpg   Anyone here running staggered rims with AWD?-img_0199.jpg
Old May 16, 2011 | 08:12 PM
WhiteLightning
really dig it! do you have any idea how i can calculate what possible OD's i can do with my car?
Old May 16, 2011 | 09:38 PM
coolraz's Avatar
coolraz
Use that site....seriously (I spent hours on it lol). Here's the way I would recommend you use it:
First, put in the OEM specs 225/50/18 (not sure about offset), then put in the front wheel you want. Check to make sure it's pretty close in diameter (should be within 1%) and put in the offset you want, it will tell you whether that offset should work or maybe a problem. Then put in that front wheel specs and put in the rear wheel in the second column. Make sure the rolling diameters is EXACTLY equal, no point in subjecting the AWD to even a little difference here. Lastly, put in the OEM specs back in 1st column and the rear wheel specs in 2nd, check which offsets would work. The setup you posted on the other thread the wheel's rolling diameter was gonna be different.
Anyway any of the offsets vossen sells for g37 is a direct fit UNLESS you have a BBK installed. The offsets are posted whenever Jav announces a wheel so just search for that thread for whatever wheel you want and look at the available offsets. Just email them to double check, but for a g37x you shouldn't have any issues. I have no idea for the other wheel brands : )
Last edited by coolraz; May 16, 2011 at 09:53 PM. Reason: how to use the site (in my experience)
