Help enkei rpf1
Old Feb 18, 2011 | 10:20 AM
1slowvq37's Avatar
1slowvq37
From: Real Del Mar Baja California Mexico , Chula Vista CA
enkei rpf1
So I want to get a set of 19" enkei rpf1 for my g37s, my car is lowered on eibachs and I want the wheels to fit perfect with no rubbing,no stretching tires or going with a crazy negative offset, my car is aligned to factory spects ( got camber kit front and rear) so here are the size available:
http://www.enkei.com/size_chart/RPF1.pdf
So which size and off set will work better for my car?
Thanks!
Old Feb 24, 2011 | 05:43 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
The only one I see that comes close is the 42mm offset, but that shows for a non sport model with the smaller brakes. Might have a caliper issue using that wheel.
Old Feb 25, 2011 | 03:38 PM
myk1013's Avatar
myk1013
+1, haven't seen anybody here with the RPF1's and I've looked into them as well in the past. Clearing the calipers will be the issue.
Old Feb 27, 2011 | 05:06 PM
1slowvq37's Avatar
1slowvq37
Yeah I've been searching and it seems they will not clear the calipers, here is the thing, I just want a lighter wheel than my stock 19" what wheels do you guts recomend?
Kojack
Sep 13, 2015 04:58 PM
huwee06
Jun 10, 2012 11:36 AM
iwasgointo
Sep 1, 2010 06:16 PM
bforbrian
Wheel & Tires
Jan 21, 2009 08:31 PM
