View Poll Results: What colour to plasti dip?
Flat black (nothing overtop of the usual black plasti dip)
31.25%
Gloss over flat
12.50%
Gloss black
25.00%
Metallic black
6.25%
AG match (or close)
6.25%
Metallic dark silver
12.50%
Somethin else (options apreciated)
6.25%
Voters: 16. You may not vote on this poll
*POLL* Plasti Dip AG rim colour?
Old Feb 5, 2011 | 12:41 AM
simpson_G37X's Avatar
simpson_G37X
soooo as usual i get an idea in my head and obsess about it until its done haha so here it is
wheels off (after fighting with the car and stands)
1st layer
finished the 2nd layer and guess what happened? if you guessed it started to rain your right! so i kicked the audi out of the garage haha
3rd
thought it was a good time to take a pict of the spacers cuz i hadnt before
5 coats later
and boom (tinted today also, overhead light messing with the picts)
i bought the rustoleum gloss black, but i was so impressed with the PD black that i decided to just go with the flat PD black.
and btw a major reason why im not dropping the car is because i have to contend with this driveway. its a LOT steeper than it looks. the audi scrapes all the time, the G is very close to scraping stock.
Old Feb 5, 2011 | 03:32 AM
tomro99's Avatar
tomro99
im glad you followed up on the process. i knew it would look good in the end. how long did it take you ? im looking forward to doing mine as well but with a gloss finish. next up you should do your grill, headlights, and rear valence!
Old Feb 5, 2011 | 10:52 AM
simpson_G37X
well i got delayed for an hour or so due to the rain, and it kinda cold here right now so it was taking a long time to dry. after removing all the wheels (which took about 45 mins haha i couldnt find any jack points!) it probably took me 4 hours including the hour delay to get the car back on the ground. did 5 coats. i wasnt in a rush. it comes out best when you do many light coats.
i bought the gloss but didnt put it on haha.
im going to be doing the grill today . and i would do the headlights if it was easy to get them out. and i dont like the black rear valence look IMO. probably going to tint the rear tail lights in the future too.
Old Feb 5, 2011 | 11:31 AM
myk1013's Avatar
myk1013
very nice!
IMO, the stock 18's split 5 spoke design looks more sportier than the 19" sport wheels.
too bad u can;t drop the car. Would've looked 10x better.
What kind of spacers do u have on?
Old Feb 5, 2011 | 01:41 PM
simpson_G37X
Originally Posted by myk1013
very nice!
thanks man
25mm rear 15mm front
Old Feb 5, 2011 | 01:45 PM
myk1013's Avatar
myk1013
brand?
Old Feb 5, 2011 | 02:05 PM
simpson_G37X
edit: deleted post
Old Feb 5, 2011 | 04:17 PM
tomro99's Avatar
tomro99
i see you used the playing card method as well. how far away were you when spraying? 1 continuous spray for one coat or...?
Old Feb 5, 2011 | 05:22 PM
Alpha Ice's Avatar
Alpha Ice
Minnesota G owners
Did you have to sand down the coating on the wheels or did it work perfectly w/o having to do anything? They turned out really well btw...Ver nice!!
Old Feb 5, 2011 | 06:28 PM
simpson_G37X
cards worked great. i found short bursts to work better. my technique which was developed haha was i did the sides of the spokes (which in turn did the face of them too) then did the lip. if there were any parts not covered i just did a quick spray over everything. i was probably 6-12" away depending.
no sanding necessary with PD. if you do sand it it will be harder to take off. just need a clean and dry smooth surface.
did the grill thismorning too
Old Feb 5, 2011 | 06:36 PM
Djfarhan's Avatar
Djfarhan
^ good looks!
Old Feb 5, 2011 | 07:00 PM
tomro99's Avatar
tomro99
that looks so much better. did you pop out the grill or did you have to take the bumper off?
Old Feb 5, 2011 | 07:08 PM
dal1307's Avatar
dal1307
Originally Posted by RaulGCustom
I say no plastidip IMO. Just doesn't leave the quality finish paint does. I say lower the car, would also make a dramatic difference.
* Lower
* Tint
* No front plate
* Paint Headlights
From what I have seen Raul knows how to make a vehicle look sharp. I would take his advice.
Old Feb 5, 2011 | 07:09 PM
  #29
dal1307's Avatar
dal1307
Although this looks pretty dang good too! Good job.
Old Feb 5, 2011 | 07:30 PM
  #30
myk1013's Avatar
myk1013
do your rear valence too. and your headlights.
J/K about the headlights.
