Infiniti TPMS Monitor?
Old Jan 1, 2011 | 11:23 PM
nishalp's Avatar
nishalp
I like the TPMS but one thing I dont like is it seems to be a too late type of deal when that sensor goes off on the dash. I have 2 questions:
1. Does anyone know at what pressure the sensor goes off? Does it have to be 5 PSI low or more? I got a flat when the light went off but when I checked my tire, it was completly flat.
2. Are there any tools out there that can communicate with the factory TPMS sensors and show the exact tire pressure? I am sure it sends it but I think Infiniti does not show it anywhere..
Old Jan 1, 2011 | 11:35 PM
rks's Avatar
rks
There are manufacturers that wil pinpoint the actual tire but I haven't seen any that display the actual pressure. I 'think' the pressure has to be below 26 psi for the TPMS lamp to trigger.
Old Jan 2, 2011 | 12:42 AM
kmp's Avatar
kmp
It's odd that Nissan shows the actual number on my Nissan Murano (it's an '85) and not on my Infiniti. It won't show the actual number until 30 mph but that's better than a damn light.
Old Jan 2, 2011 | 04:37 AM
Hapa DC5's Avatar
Hapa DC5
My TL use to give me a reading of each tire on the MID.
Old Jan 2, 2011 | 07:47 AM
Chico's Avatar
Chico
In the voice commands section of the Navigation manual, there's this voice command listed: "tire pressure." According to the manual it will display the tire presure if so equipped. I tried it and nothing happened. My guess is that this is a feature on the M.
Old Jan 2, 2011 | 01:11 PM
nishalp's Avatar
nishalp
Seems the M has alot of things that I want now.. Guess I am going to have to upgrade sometime in the future...
Old Jan 2, 2011 | 02:36 PM
dkmura's Avatar
dkmura
20 Year Member
The Infiniti TPMS is factory set to trigger the warning when the actual tire pressure drops 25% from optimum. If there's a sudden loss of pressure from a cut or damaged tire, the warning can only serve to help you get out of the throttle and begin manuevering for an exit. By the time you stop, the tire will be flat.
Old Jan 2, 2011 | 07:14 PM
Chico's Avatar
Chico
It could also be a feature in the Technology Package for the G. anybody with the Tech Package that can check on it.
Old Jan 2, 2011 | 08:38 PM
nishalp's Avatar
nishalp
Got it fully loaded.. Not a option left and it is not there..
Old Jan 3, 2011 | 09:08 AM
KLB's Avatar
KLB
They dropped the ball on this one. Cheap Dodge's will give you the pressure too.
Old Jan 3, 2011 | 09:19 AM
ScottyBeGood's Avatar
ScottyBeGood
The TPMs sensor is meant to go off when the tire inflation reaches 26 psi.
Old Jan 3, 2011 | 09:31 AM
Coprolite's Avatar
Coprolite
Even my TSX/Tech has this. It allowed me to tweak mpg and comfort. It was very accurate and allowed me to be quite lazy with checking the pressure manually.
I did end up buying tire/rim protection with the G, as I blew a tire on the TSX while travelling during the first month and the rim still has a mark on it! It will also protect it from someone in my family who likes curbs...
Old Jan 3, 2011 | 11:41 AM
cvipgo's Avatar
cvipgo
Infiniti 2005 FX45 does show exact pressure of each tire but the newer Infiniti 's have idiot light warning when pressure drops below preset value.
Old Jan 3, 2011 | 11:49 AM
blackfunk's Avatar
blackfunk
08 FX's show the psi for each tire. Our setup is just lame. It requires you to check each tire which happened to me recently in the rain. Couldn't tell by just eyeballing it which tire was low, and being that I have three patches it really did require me to pretty much check them all in the rain. I was not happy.
Old Jan 4, 2011 | 01:50 PM
mossman's Avatar
mossman
I have heard that idiot light is now done on purpose. The thought is that you will be forced to manually check the pressure of each tire. Not saying I agree with it, but jut what was told to me.
As a side note Acura does tell the tire pressure of each tire. This creates other problems. For example someone I know won't drive the car if one tire reads 31 psi and the rest read 32psi...
