tires and wheels
tires and wheels
im looking at getting a new set of rims/wheels. what im wondering is, if I upgrade to 20's, do I need to get 2 different sized rims for the back and 2 different sized for the front? and then also get different sized tires for each?
or can i get 4 of the same size rims and 4 of the same size tires? will this cause any performance issues?
go into the wheel+tire section and there are plenty of threads talking about it.
quick answer -- any set you buy will have wider rear wheels than front. for example mine are 20x8.5 and 20x10. The corresponding tires are 245/35/20 and 275/30/20 (although you can get many different size tires depending on what you want).
If you have AWD then there are some considerations you need to take. But again, read all the threads in the Wheel+Tire section
quick answer -- any set you buy will have wider rear wheels than front. for example mine are 20x8.5 and 20x10. The corresponding tires are 245/35/20 and 375/30/20 (although you can get many different size tires depending on what you want).
04G35NYC
May 2, 2016 05:15 PM
