people who have 20' GT30s +35 FT/+37 RR
Old Jul 13, 2010 | 01:19 AM
Staples's Avatar
Staples
10.5" rear on a 285 will rub unless you're running over -2 degrees of camber. The fender lining will have to be trimmed and so will the actual bumper bracket. I'm running a fairly subtle rear offset at 39, and I was rubbing at 1.25" drop in the back with -1.8 of camber.
Old Jul 13, 2010 | 01:38 AM
So if someone were dropped less than 1.25" or had a less aggressive offset they may not rub, right?
Old Jul 13, 2010 | 02:06 AM
Staples's Avatar
Staples
Possibly, it all depends on the amount of negative camber the person wants to run in the back. -1.8 is the most amount of negative you can go to stay within spec in the rear (-1.2 in the front) otherwise anything more then that is considered aggressive.
Old Jul 13, 2010 | 02:07 AM
KennethG37S's Avatar
KennethG37S
so... 245/35or30/ FT, 275/30or25 would be the best tires? I mean without any trimming or something.
Old Jul 13, 2010 | 12:27 PM
Loi's Avatar
Loi
Yea, tht's what I have, and zero issues. But I'm going with 255/35 275/35 once these wear out.
With my current set-up, I feel that the front is too stretched, and the rear tire is too thin. So I'm going with wider front, taller rear, even tho the rear might throw the speedometer off just a bit.
Old Jul 13, 2010 | 12:54 PM
myk1013's Avatar
myk1013
OP...
I have 255/35 and 285/30, dropped with Eibachs....
I have rubbing issues on moderate dips and bumps, also when I go up a steep ramp in an angle.
maybe your 285/25 combo will work.
Old Jul 13, 2010 | 12:56 PM
Ivoidwarranties's Avatar
Ivoidwarranties
Originally Posted by myk1013
OP...
Where are you rubbing at? What width are your rims and do you know the backspacing?
Old Jul 29, 2010 | 06:21 PM
KennethG37S
I need to decide what size of tires i should put.. my gt30s have been in my living room for like a month lol
Old Jul 29, 2010 | 07:52 PM
myk1013's Avatar
myk1013
10.5" in back. Same specs as all the GT-30's for the G37.
the edge of the tire rubs on the felt fender liner material. I haven;t trimmed the bracket yet.
Old Sep 17, 2010 | 05:48 PM
christian655321's Avatar
christian655321
hey , thanks - this thread helped me out also.
Old Sep 17, 2010 | 06:02 PM
ReddieG37's Avatar
ReddieG37
with those specs, here are the tires I would get..
245/35 front
275/30 rear
this will keep overall wheel diameter same as stock so your speedometer will still read accurately.
As far as rubbing, it's all dependant on wheel width, offset, negative camber, and tire. I had pretty much the same setup as you with the tire sizes listed above. Ran Toyo T1R's with no rubbing issues. Switched to Nitto NT555 and my rears were rubbing on big dips. I ended up trimming the fender lining and bracket.
Hope this helps.
Old Sep 18, 2010 | 07:01 PM
christian655321
I went off of Black Bettys recommendation 255/35/20 and 285/30/20 , still waiting on the wheels so I will let you know when I have them installed. running KW v3
Old Sep 19, 2010 | 12:05 AM
KennethG37S
I have 245/35/20, 275/30/20 now.. I think they are okay.
Old Sep 19, 2010 | 01:00 AM
  #29
GraphiteG37S's Avatar
GraphiteG37S
I'm have Volk GT-7's, not GT-30's with the same offsets as described by OP.
I'm running 255.35R20 front & 275.30R20 rear. I'm dropped on Ebach and have zero clearance issues. My rear tires are pretty stretched being Falken FK452. Next time I think I'll go 285 in the rear.
Old Sep 19, 2010 | 11:21 PM
  #30
VRG37S's Avatar
VRG37S
I have GT-7'S as well with the same offsets. 20x9.5" 35mm up front and 20x10.5" 37mm in the back. With 245/35/20 and 285/30/20 in the rear. I don't really like the way the 245 tire looks on the 9.5" wide wheel. I would really like to try and run a 275/35/20 up front. The 285 looks perfect on the 10.5" wheel. IMO.
