2009-2010 OEM 18" Coupe wheels fit 2009 G37X Sedan?
Hello all! I am asking a question that I am pretty sure I already know the answer to, but just wanted confirmation. I have a 2009 G37x sedan, and am looking for a set of decent summer wheels/tires. My plan is to mount a set of snow tires to my stock 17" wheels for the winter, and pick up another set of wheels/tires for the warmer months here. I'm not looking for anything too fancy, but would like to keep my approximate tire diameter (don't want speed-o issues), but with a wheel that takes up a little more of the gap in the fender wells. I would also like to run a slightly smaller sidewall than the uber-tall 55-series the car comes with, along with more aggressive summer tires.
For all of these things, I think a set of factory 18" wheels that come stock on the G37 coupe would work great! Specifically the double 5-spoke design, as I like their simple look, and with measurements of 18 x 8.0" (verified via Infiniti's spec page) all around, they seem to be a perfect fit. I'm fine with the 225 contact patch width, and think the 50 series height would be just fine to still keep a nice, smooth ride. From what I understand, the standard 18" coupe wheels are not staggered, so I'm assuming there should be no issues there. I'm pretty sure all G37's have a 5x114.3 bolt pattern, so I don't see an issue there. Although I think the AWD sedans have a 45mm offset, and I think the 18" coupe wheels have a 43mm offset. That seems pretty minor, but does anyone think that will pose a problem?
Just to be clear, these are the wheels I'm referring to:
I'm pretty sure these should fit without an issue, but figured I would post up here prior to picking a pair up just in case someone knows something I don't. Anyone have any reason why these won't work, or am I good to go?
Thanks in advance!
-Brandon
Thanks in advance!
-Brandon
To anyone who was curious, I actually bought a set of 18" coupe wheels from a guy on Craigslist this past weekend, and not only did they fit without a problem, they look MUCH better than the stock 17's!
I snapped a quick pic of them with my sub-par POS iPhone cam:
This raises a question for my future upgrade. I have 09 G37x Coupe with the wheels shown above. I want to install the Akebono BBK. Will it interfere with the spokes? Just want to make sure before I buy the kit and realize I can not install it. Thanks!
NN
NN
