2010 g37s sedan wheel info
Old Jun 24, 2010 | 01:04 PM
GmOnEy1's Avatar
GmOnEy1
I'm lookin to upgrade my wheels I'm lookin to get 19.9 front with 245/45 tire with 35 offset and 19.10 rear with 275/40 tire with 35 offset will this fit with stock suspension and with eibach pro kit springs thanks
Old Jun 24, 2010 | 01:13 PM
Sunny G's Avatar
Sunny G
It will fit no problem. I'm running 20x9+25 with spacers with an eibach drop and they fit perfect without rubbing on the fender
Old Jun 24, 2010 | 01:19 PM
GmOnEy1's Avatar
GmOnEy1
Thanks one more thing will there be a prob with rubbin cause the cars leased n I'm not lookin to be cuttin n messin anythin on the car
Old Jun 24, 2010 | 07:27 PM
gundam83's Avatar
gundam83
I'm running 19x10 38 offset w/ 275/35/19 tires and the rear sticks out a bit. My coilovers are set to around an eibach pro drop, and even with -3 degrees of camber I can get the rears to rub. If I could do it over I'd probably get 19x9.5 for the rears.
Old Jun 24, 2010 | 10:19 PM
Sunny G's Avatar
Sunny G
Ok I read your post again and saw you are going to be running some big tires so my suggestion is 245/40/19 front and 275/35/19 rear and I don't think you will have a rubbing problem. If you are worried it will rub just go with a higher offset (which I wouldn't prefer) but maybe that would help
Old Jun 25, 2010 | 01:23 PM
GmOnEy1's Avatar
GmOnEy1
What if I went with a 19x9.5 rear with a 275 40 tire n 19x9 front with the 245 45 tires with the 35 offset front n rear n wouldn't I wanna get as close to zero camber with the drop or would that be a issue I'm in new York so I need to run bigger sidewalls n I drive the car hard n thanks for the feedback guys
Thedbarz
33
Feb 9, 2016 12:05 AM
maybeg37
Sep 8, 2015 02:33 PM
connoisseurr
Sep 2, 2015 09:18 PM
pcwd
Aug 12, 2015 06:54 PM
asato3
Aug 7, 2015 08:45 AM
