Help Plus Zero Tire ( What Air Pressure?)
Old Feb 10, 2010 | 02:50 AM
808MIKE's Avatar
808MIKE
Sups! getting ready to make the switch to Plus Zero size my G37 Coupe 19's.
Putting the 245/40/19's on the front, and the 275/35/19's on the rear. so what is the correct air pressure to use now? I know Stock sizes were 35psi cold. is it still 35? or need to add more? my tire guy said he will inflate the new tires to 40 psi, cold? is this good? or need to reduce back to 35psi cold? Appreciate the info! Thnx.
Old Feb 10, 2010 | 05:14 AM
Staples's Avatar
Staples
I run 35psi during the winter for a little added traction, and 40psi during the summer when the roads are warm.
I use those same exact tire dimensions on my setup too.
Old Feb 10, 2010 | 05:22 AM
B L U E S L A T E's Avatar
B L U E S L A T E
32psi cold.
Old Feb 10, 2010 | 02:39 PM
Same pressure as OEM. Go up 1 pound if you want to.
charneco
Feb 21, 2016 11:11 PM
luisalan
Sep 6, 2015 05:45 PM
