Sedan with Coupe 19's
Old Feb 13, 2010 | 07:00 PM
DEC1's Avatar
DEC1
it has wheels....winter wheels and tires...just not oem stock
Old Feb 13, 2010 | 11:08 PM
mw09g37's Avatar
mw09g37
thanks for clarifying.
Old Feb 15, 2010 | 02:49 PM
BlackjackM's Avatar
BlackjackM
I think the sedan looks great with the coupe's 19s. Would there be any issue putting these 19s on a G37x considering the AWD factor?
Old Feb 15, 2010 | 02:51 PM
mw09g37's Avatar
mw09g37
a quick search of the forums could've answered this question... this has been covered MANY times.
the S wheels are staggered. isn't recc to run them on the AWD system.
Old Feb 15, 2010 | 03:02 PM
BlackjackM's Avatar
BlackjackM
Thanks for the quick answer, that's a bummer cause your car looks great with them.
FWIW, I tried to search but it was a tough one to come up with the correct terms for
Old Feb 15, 2010 | 03:04 PM
mw09g37's Avatar
mw09g37
it's there, g37x staggered, 19s all work.
but
it's not that you can't use them. you just have to do them correctly ie not staggered.
so 4 front or 4 rears. no 2/2
Old Feb 15, 2010 | 11:47 PM
cdso's Avatar
cdso
but
Right. I think for the non-sport it's 17x7.5 and 18x7.5 for the sport package. Makes it a little harder to find a set of 4 fronts or rears. The look is awesome though!
Old Feb 22, 2010 | 08:59 PM
cdso's Avatar
cdso
I'm looking at getting a set of the 19s for my g37 x sedan. Not knowing much about wheels, would the fitment be easier if I went with 4 fronts (19x8.5) as opposed to 4 rears (19x9)??
Old Feb 22, 2010 | 09:03 PM
eauty's Avatar
eauty
Considering the X comes with wheels that are 7.5 in wide I would stay closer to the 19 x 8.5 just to isure your clear everything. Check out the wheel calculator to see how different wheel and tire configurations would look with the sedan. It takes into consideration suspension, speedometer readings etc.
Old Mar 2, 2010 | 08:53 PM
DEC1's Avatar
DEC1
wheel calculator?...can you tell me where to find it?
Old Mar 2, 2010 | 10:47 PM
eauty's Avatar
eauty
Its just above this set of posts in the "OEM " wheel specs... its awesome to show you what affects different size tires and wheels have on the car, speed etc.. a great tool Wheel / tire size calculator / comparer - BIGCUSTOMWHEELS
Old Mar 7, 2010 | 05:16 PM
scotimike's Avatar
scotimike
New and full of curiosity...
I have an 09 G37 sedan and just had the 19" sport rims off an M35 put on. The dealer told me too that they wouldn't fit so I grabbed some 5mm spacers. They fit good with no rubbing but vibrate to all hell at 75mph. Taking them off this week to see how they fit. Anyone know the cost to install H&R sport springs in the Phoenix area?
Old Mar 7, 2010 | 06:27 PM
cdso's Avatar
cdso
Pics?? Is it a balance issue?
Old Mar 13, 2010 | 10:42 PM
  #29
Jamler's Avatar
Jamler
That sedan looks totally hot with those coupe 19's.
Old Mar 19, 2010 | 11:54 AM
  #30
Austin713's Avatar
Austin713
G35 S on stock suspension with G37 19s.
Also, does anyone know if you can run 245/40/19 all around??? those are alot cheaper than upgrading the rears to the 275/35s
P.S. not my car BTW.... although working on some G37s right now..... let me know if anyone wants to sell thiers
