S-Drives - replacing OEM - what size?
Old Jan 24, 2010 | 08:54 PM
iansw's Avatar
iansw
08 Coupe S here....replacing OEM 19" Tires with new ones.
I see all over the board these sizes posted for OEM replacement:
Front: 245/40/19 OR 245/35/19
Rear: 275/35/19
Seems the consensus on the rear is 275/35/19.
On the fronts, I see lots of postings about either of the different sizes, but no discussion of why you would go with a 40 or 35.
So - which is better and why?
Note my car is on BC Coilovers and dropped about 2". Is the drop what makes the difference for people? Does one size look better/perform better than another?
I admit fully I don't know crap about tires.
Thanks
Old Jan 24, 2010 | 09:00 PM
G37Sam's Avatar
G37Sam
For the fronts:
40 means you'll have a tire sidewall of 0.4*245 = 98 mm's
35 means you'll have a tire sidewall of 0.35*245 = 85.75 mm's
OEM (225/45/19) sidewall is 0.45*225 = 101.25 mm's
You want to try and stay as close to the OEM sidewall height as possible, that's why everyone runs 245/40/19
Another thing to keep in mind is, going with a shorter sidewall means your ride will be sitting even lower.
Old Jan 24, 2010 | 09:25 PM
HamstersG's Avatar
HamstersG
While Sam is technically correct, it is easier just to look at or calculate the total height of the tire. Here is a link that should help. Note there is an attachment you can download and stare at: Tire Size Table.
Old Jan 26, 2010 | 06:31 PM
Neal@tirerack's Avatar
Neal@tirerack
MYG37.COM Platinum Sponsor
245/40-19 front 275/35-19 rear most common fit.
Team_STILLEN
Future Models
13
Sep 5, 2016 03:13 PM
connoisseurr
Sep 20, 2015 04:14 PM
KAHBOOM
Aug 25, 2015 11:05 AM
connoisseurr
Aug 16, 2015 04:26 PM
RoyalG37
Aug 11, 2015 12:21 PM
