You can do it, but it will make the rear tire look proportionally larger than your front given the sidewall on the rear is close to 1/2 larger than the front. Much better to run 275/35 in rear. Here is a place that is good to play with the sizes. http://www.wheelsmaster.com/rt_specs.jsp
Originally Posted by Q8_G37S_Red
to run rear 275/40/19 on rear an 245/40/19 in front ??
for stock rims ?
