Need quick helppppp
Old May 11, 2009 | 04:04 PM
nostalgia85's Avatar
nostalgia85
Need quick helppppp
my friend offers this to me he had this on 350z 07 should i take it? im not into sus and rims. spring will perfectly fit on g37s?
please gimme an advice
volks GTS mercury silver
Rims
front 19-9.5 +17
rear 19-10.5 +18
Tire
nitto invo
front 255/35/19
rear 285/35/19
spiein gf210- 1inch front 1.2 rear
everything is 1800 bucks
what do u think?
http://img219.imageshack.us/img219/2373/p5110033.jpg
http://img219.imageshack.us/img219/8360/p5110031j.jpg
http://img219.imageshack.us/img219/7278/p5110032y.jpg<!-- google_ad_section_end --> <!-- / message -->
Old May 11, 2009 | 04:05 PM
aznutx's Avatar
aznutx
seems like a very good deal for volks, dunno if they fit/clear brakes etc but if u like the way they look and they fit, get them
Old May 11, 2009 | 04:06 PM
SOLISIMO's Avatar
SOLISIMO
there is no way they will fit, Im running a +25 offset and thats agressive with a spacer to clear the brake
Old May 11, 2009 | 04:07 PM
TicketProof's Avatar
TicketProof
i like those rims alot and thats a decent deal too. Their not much bigger then stock but will look good especially with the drop from the tein springs.
nostalgia85
so you think it's a good deal? im not into rims so i dont; know anything
rims are clean and tire seems to have like 80%
i heard tires are like 250 each
take it?
Old May 11, 2009 | 04:08 PM
SOLISIMO's Avatar
SOLISIMO
You guys look at that offset dont lead him on , yeah they look great but they wont fit
Old May 11, 2009 | 04:11 PM
nostalgia85
this is what i found on website
G37 OEM Wheels Specs
Sport
Front: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
G37
non sport
Front & Rear 18x8 +43mm offset
Commonly used after-market offsets:
Front width: 8.5" +30-35mm offset
Rear width: 9.5" +30-35mm offset
Old May 11, 2009 | 04:12 PM
nostalgia85
so there is no way it will fit?
Old May 11, 2009 | 10:44 PM
GiGGaplease's Avatar
GiGGaplease
whos the noob that deleted my useful information!?
oh it fit alright, it will just stick out all ghetto.
low 20s offset front and high 20s offset rear. it will look sick with those offset<<<<<.
Old May 11, 2009 | 11:03 PM
NIGHTLFEphantom's Avatar
NIGHTLFEphantom
it will fit. but like my nikka gigga said... it stick out like this but a little less:
Old May 11, 2009 | 11:22 PM
Kidcane's Avatar
Kidcane
Florida G Club
Those wheels will not fit on your car without sticking out.
Old May 11, 2009 | 11:24 PM
aliiin's Avatar
aliiin
BMW Defector
if you like that look, then go for it!
mahadeod
Oct 6, 2015 01:02 PM
Chappedj
Sep 28, 2015 03:20 PM
czirrfb
Sep 16, 2015 04:09 PM
