The 19x8.5 +25's will be ok on the front, but 19x10.5 with a +29 will stick out pass the fender with or without a drop. If you're going to do a 10.5 on the rear you don't want to go lower than +37. You don't want to spend that kind of money for it to look Hood. If you ride in Baton Rouge, the roads won't be kind either.
Also what size tires would be best. Car is not lowered.
Thanks
Derrick
The front is fine, the rear will stick out, but since you said its not lowered, as long as you don't have alot of weight in the back you should not rub
Easy people. I have the exact same size rear on my car and they are going to stick out a little bit without a drop. At first I had them tucked a little bit by dialing in the camber but now my camber is just about back to spec after SPC camber kit and I do rub a little on steep inclines or when I roll with 3 fatties and a full tank of gas.
