Help Leaky tire
Old Nov 28, 2008 | 12:06 AM
BiskitG37's Avatar
BiskitG37
I had this happen to my old G35 coupe. The dealership wound up taking the tire off, and remounting it. Seemed to fix whatever the problem was. It didn't show air bubbles in water either.
Old Nov 28, 2008 | 12:08 AM
jedmonds's Avatar
jedmonds
Thanks for your input, but the 2nd place I took it to, did dismount the tire.
Old Nov 28, 2008 | 12:10 AM
Weiboy718's Avatar
Weiboy718
Originally Posted by jedmonds
So I've taken my car in to three different places because my rear driver side tire has this slow leak which is becoming a pretty fast leak, but each place can not seem to find leak. No air bubbles when then submerge the entire wheel in water. What is weird is when it gets really really cold, it loses a ton of air, but if its pretty warm during the day, its fine. It seems its getting worse and worse over time. From yesterday to this morning I lost about 15 psi. I drove to finalge's place and he was kind enough to let me borrow a driver side rear wheel/tire while I figure out what I need to do. Anyone have any similar experiences, or any other idea's that could be causing this? Could it just be a bad tire? the Wheel it self is not warped, and does not have any damage to it.
i had something similar with my sevas! the tire was losing 15psi within 6 hours after i filled it up. it's weird cuz nobody found where the leak was at until i took the wheel off my car and inspected myself. it took me 45 minutes just to find that leak. try to check the bead and the air valve.
Old Nov 28, 2008 | 12:13 AM
jedmonds's Avatar
jedmonds
Funny coincidence, I am having this issue with my Sevas. What ended up being the problem and solution to your leak?
Old Nov 28, 2008 | 12:25 AM
elite's Avatar
elite
Get a new car pronto!
Old Nov 28, 2008 | 12:42 AM
Stanced370Z's Avatar
Stanced370Z
It's the SEVAS wheels! They're 3 piece wheels and one of the seals isn't sealed on completely. That's exactly why they can't find the problem and why it's leaking. Man I feel bad for people that dished out money for 3 pieve Sevas, cause all I've heard is problems with their wheels.
Old Nov 28, 2008 | 12:44 AM
Weiboy718's Avatar
Weiboy718
[QUOTE=jedmonds;2475250]Funny coincidence, I am having this issue with my Sevas. What ended up being the problem and solution to your leak?[/QU
we found the tire was leaking from the bead and tried to put some bead sealer on it but still no luck.
my tire shop guy recommended me getting wider tires cuz 275 seems kinda stretch on an 10.5 wheel. unlucky me got a blow out on the front before i fixed the rear and now two wheels is back to sevas for repairs. try to check harder where the tire and wheel meets.
Old Nov 28, 2008 | 12:46 AM
jedmonds's Avatar
jedmonds
[QUOTE=Weiboy718;2475273]
Thanks for the info Weiboy.
Old Nov 28, 2008 | 12:47 AM
Weiboy718's Avatar
Weiboy718
[QUOTE=jedmonds;2475275]
no problem!
Old Nov 28, 2008 | 07:28 PM
jedmonds's Avatar
jedmonds
America's tire found a bead leak, so they tried the bead sealant. I don't have the wheel on my car, because I want to monitor the air pressure to see if that fixed the problem. Thanks again for the tip weiboy.
Old Nov 28, 2008 | 09:29 PM
w0ady's Avatar
w0ady
hope thats it...
Old Nov 29, 2008 | 01:04 AM
Weiboy718's Avatar
Weiboy718
damn! that's the same sh** like mines! hopefully the bead sealer will help! be sure to keep an eye on it after you drive it. and if it still leaks. you might wanna try 285/30 tires. sevas wheels! never again!
Old Nov 29, 2008 | 01:09 AM
jedmonds's Avatar
jedmonds
I tried 285/30's before. They rub like a ****...
Old Nov 29, 2008 | 01:18 AM
  #29
Weiboy718's Avatar
Weiboy718
you must have very aggressive offset! have you tried shaving down the fender liner?
Old Nov 29, 2008 | 01:26 AM
  #30
jedmonds's Avatar
jedmonds
The offset for the rear is 26. Its not rubbing on the fender linger, but the little plastic nub thingy that connects the rear bumper to side body of the car. I've already cut as much as I could of that...
