Offset no good?
Old Oct 27, 2008 | 02:51 PM
Graham's Avatar
Graham
Offset no good?
http://cgi.ebay.com/ebaymotors/MAYA-...1%7C240%3A1318
The offset on these wheels seems to have them tucking too much for a G37, mind you I have just the Journey Premium so I don't have as many brake clearance issues. But I'm more so used to seeing offsets like 30 and 35 for our vehicles, correct? These wouldn't look right fit wise on a G37?
Old Oct 27, 2008 | 02:52 PM
Kidcane's Avatar
Kidcane
Florida G Club
Cant see EGay at work. What are the size offsets?
Old Oct 27, 2008 | 02:53 PM
Graham's Avatar
Graham
"maya rm1 20". Staggered (f) 9.0+30 / (r) 10.5+29 offset"
Old Oct 27, 2008 | 02:56 PM
Kidcane's Avatar
Kidcane
Florida G Club
Those are the same exact offset as my STM's. They fit but I had to dial the camber in a bit in the rear to avoid rubbing and make them fit.
Remember that with offsets, the lower you go the further they stick out.
Old Oct 27, 2008 | 03:03 PM
Graham's Avatar
Graham
Well these are Maya's so it would probably be similar. I see so et 20 stick out farther than et 35. I was backwards on this. It says fitment for G35 or 350Z which isn't too far off from a Journey G37 for sizing. Maybe I'll stop by and check them out since he's local. With a seller feedback of 4, I ain't paying anything until I see the wheels in person.
Old Oct 27, 2008 | 03:55 PM
GiGGaplease's Avatar
GiGGaplease
isnt the lower you go, the more it sticks in? a more negative camber.
Old Oct 27, 2008 | 05:46 PM
Kidcane's Avatar
Kidcane
Florida G Club
^^No. Think about it. A +29 sticks out a bit and needs neg camber while a +45 would be tucked under the wheels well.
Old Oct 27, 2008 | 05:54 PM
Lou@Amplified's Avatar
Lou@Amplified
without neg camber, the rear will rub, if you drop your car, it will rub more.
If the width is 10.5, ideal offset is +37 max, anything more agressive will rub
Old Oct 27, 2008 | 06:18 PM
Graham's Avatar
Graham
Typical rear offset is about a ET 40 then? What is a typical front offset that can work with something such and Eibachs or Tanabe?
Amrit.bhathal
Car Care & Detailing
Dec 29, 2015 12:20 PM
Amrit.bhathal
Sep 1, 2015 07:03 PM
