Confusion with tires...
Old Sep 13, 2008 | 12:00 AM
Skyline-LEXY's Avatar
Skyline-LEXY
Unhappy Confusion with tires...
Is it just me or the pictures look really different.
I was looking at GiGGaplease's and Gan78mao's tires...
but i noticed GiGGaplease's tire look a lot more square and thicker compare to Gan78mao.
245/40/19
275/35/19
BTW does it hurt to go slower than OEM diameter?
I know your not going the same speed rate when you go smaller. Is that the only thing thats bad? Is that even bad?
I noticed a lot of people in this forum used:
245/35/19
275/30/19
These sizes are at least 1" smaller in diameter compare to OEM.
Old Sep 13, 2008 | 12:57 AM
GiGGaplease's Avatar
GiGGaplease
its the company. some companies have thicker sidewalls while others have thin sidewalls for the same tire sizes.
it wouldnt hurt if you go with 35/30 on 19's. ask unv for his opinion, he has those sizes.
Old Sep 13, 2008 | 02:06 AM
The1andOnly's Avatar
The1andOnly
Yeah, it really depends on the brand. Give Lou a call tomorrow. He can suggest to you which brands will work the best for you.
Old Sep 13, 2008 | 12:03 PM
rossab's Avatar
rossab
245/35/19
275/30/19
IMO you are better off reducing the size of your tire from a performance standpoint. You will reduce some unsprung weight by smaller sidewalls. You also bring the majority of the rotational mass closer to the center point of the wheel. You also tighten up your drive ratio a bit ( a tire with a smaller circumfrence is going slower at that a normal tire at the same RPM). All three effects probably don't amount to much as far as performance gains, but it's something. Only crappy part is your speedo will be fast by a bit.
Old Sep 14, 2008 | 09:41 AM
NJlakeshoreG's Avatar
NJlakeshoreG
if u want a aggressive drop and offset and dont want 2 rub you need a more rounded sidewall tire...my vredestein tires are nicely rounded, that oculd be a big reason y i never rubbed on tein stechs and 20x9 and 20x10.5 rims 245 30 and 285 25 tires..
Old Sep 14, 2008 | 03:09 PM
Skyline-LEXY
looks like you went with smaller diameter by 1" in the front and 2" in the rear.
Old Sep 14, 2008 | 03:45 PM
GiGGaplease
dont go with thick sidewalls. i rub even though im not even dropped.
Old Sep 14, 2008 | 04:13 PM
Keng's Avatar
Keng
Correct me if I am wrong, but shouldn't smaller circumference result in faster rotation compare to larger circumference?
Old Sep 14, 2008 | 05:04 PM
GiGGaplease
yes, it will rotate faster but it wouldnt go any faster in the mph term.
Old Sep 14, 2008 | 05:24 PM
Keng's Avatar
Keng
So his statement should be
"( a tire with a smaller circumfrence is going faster at that a normal tire at the same RPM)."
Old Sep 14, 2008 | 10:10 PM
Skyline-LEXY
Going with smaller tire means your not going to drive as fast as the speed is telling you on the dash board. Example, our OEM tire diameter 27" front 26.8" rear. So lets say you went with 25.8" rear this means your losing 2.8mph (3.7% slower)
Old Sep 14, 2008 | 10:19 PM
GiGGaplease
for like example, if you go with a bigger size tires than oem. it will rotate slower but you are really going faster than what is indicated on the speedometer.
Old Sep 15, 2008 | 03:43 AM
Keng's Avatar
Keng
Gotcha, better remember that when you change the tire size or it's speeding ticket waiting to happen
Old Oct 12, 2010 | 09:04 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
Informative!
Old Oct 14, 2010 | 01:23 PM
G_rev's Avatar
G_rev
look at that little puppy >____< so cute
