Quick question concerning offsets
Old May 15, 2008 | 12:02 PM
Kidcane's Avatar
Kidcane
Florida G Club
G37 is adjustable from the factory but you are limited. If you drop it more than 1.5" you may want to get a cmaber kit or just burn through tires faster then you normally would.
Old May 15, 2008 | 12:17 PM
Protein Shakes's Avatar
Protein Shakes
That's what I was thinking, thanks
Old May 15, 2008 | 08:54 PM
sumo8me's Avatar
sumo8me
So I was thinking of getting the Piaa Super Rozzas and i thought 20x10 and 20x9s with a 25 offset would fit, but are you guys saying it wont without sticking out of the fender? the next offset size is 42...
Old May 16, 2008 | 01:55 AM
symalik's Avatar
symalik
You can get +25's. Fronts should be fine I think, for the rears aggressive negative camber/drop and pull the fender a bit maybe or you can get +42 for the rears and that should fit fine.
Old May 16, 2008 | 03:01 AM
CrazyRuskie's Avatar
CrazyRuskie
Crazy Russian Super Mod
I think the 20x10 +25 will fit with some camber adjustments
Old May 16, 2008 | 09:45 AM
Kidcane's Avatar
Kidcane
Florida G Club
^^Exactly. You are giving up a half inch in wheel size and only taking back about 5mm. Do the math. You should be fine. It on a 10.5 rear that 29-30 is the most you can go.
Old May 16, 2008 | 10:29 PM
sumo8me's Avatar
sumo8me
Thanks guys
Feffman
SouthEast
Oct 11, 2015 08:55 AM
Feffman
Upcoming Events
Oct 8, 2015 08:16 AM
OldG37
Sep 6, 2015 10:38 PM
footballmania32
Sep 4, 2015 02:17 PM
Detailed Image
Lighting/Cleaning Products
Sep 4, 2015 08:14 AM
