Are your 20s rubbing? Click here for solution!
Old 08-20-2008, 10:30 AM
  #31
Buddy Revell
Buddy Revell's Avatar
YEs there 10.5s and the GT30s offsets are 37 and 35...
Thanks. I wonder if I'd be able to run 275s on my 9.5", 24 offset GT-Cs in the rear? I'm on stock springs.
Old 08-20-2008, 04:04 PM
  #32
Blackjack
Blackjack's Avatar
Max is right. My offsets are +35 Front and +37 Rear.
Old 08-28-2008, 04:55 PM
  #33
xbuhhx
xbuhhx's Avatar
so how about 20x10.5 in rear with +34 offset dropped on tanabe nf210 and 275 tires....think that would need some trimming?
I got 20x9.5 and 20x10.5 gtc +34 offset all around coming for the G
Old 08-28-2008, 09:05 PM
  #34
Blackjack
Blackjack's Avatar
It will be close... I'm not too familiar with the Tanabe springs. My guess is you will rub over large bumps only.
Old 09-03-2008, 11:57 AM
  #35
IP37
IP37's Avatar
bump.
rubbing sucks. just finished trimming mine some more
and just a thought for the people who trim their bracket.. you may want to put some paint or something over it after trimming, because the metal that you trim will rust
Old 09-03-2008, 12:18 PM
  #36
UNV-IT46
UNV-IT46's Avatar
for those of you running 19"s if you run a 30 rear sidewall you wont rub and wont need to trip the bracket. same goes for 20"s but you must run a 25 rear side wall. your tire choices drop big time. but you wont need to trim
Old 09-03-2008, 12:53 PM
  #37
The1andOnly
The1andOnly's Avatar
Hey UNV, what size & offset are your GTM's in the rear? Also, what sidewall? I'm rubbing right now, and I'm running 10.5 +33 w/ 275/35.
Old 09-03-2008, 12:54 PM
  #38
UNV-IT46
UNV-IT46's Avatar
10.5 +36 275-30.. zero rub. the 30 side wall is key
Old 09-03-2008, 01:33 PM
  #39
The1andOnly
Ahhh. I think I'll jest have the rear raised up a bit more. There's only about a 1/2 finger right now. I was rubbing a lot before they stiffened my shocks one setting, and that helped out a lot.
Old 09-06-2008, 02:37 AM
  #40
Volk350z
Volk350z's Avatar
not sure if anyone post this but the rear bumper bolts I just redrill a new holes further back and now no rubbing and can go lower offset...
Old 09-06-2008, 12:57 PM
  #41
The1andOnly
Just got some trimming of the liner and some grinding of the bumper bolts yesterday at Amplified, and it's all good now .
Old 11-05-2008, 08:08 AM
  #42
chamelieon
chamelieon's Avatar
anyone have pics of how a 275 tire looks on that 10.5 equivalent rim. or anyone has done any comparisons on how tire widths look on the same rim? kinda helps people to choose the look they want to achieve. or whats the smallest sizes we can run and highest. i would put the 285 as the highest just by seeing blackjacks setup.
Old 10-29-2009, 09:45 PM
  #43
Age
Age's Avatar
I'm at stock height right now with 285/30/20 in the rear and they only time I hear a scrub or rub is when I go over a big dip on the street, do you think I should just try the cut some of the lining out? If that doesn't work then I guess I'd grind some of the bracket.
Old 10-29-2009, 09:53 PM
  #44
JKashat
JKashat's Avatar
I got 305's w/ KW & SPC Camber and don't rub on the bumper bracket. I did trim the fender lining. All I used was a razor blade and only cut off a bit inside of where it rubbed through. Love the look of 305's but if I keep the car long enough for another set of tires will probably go to 285's. Just my 2 cents.
And, for the record, Ryan and Sharif at Forged are the Sh*t. Always take good care of me.
Old 05-11-2011, 11:42 PM
  #45
cereal2k
Mr. Drop it like it's hot
cereal2k's Avatar
Originally Posted by IP37
bump.
I found this quite helpful. Thanks all!
Quick Reply: Are your 20s rubbing? Click here for solution!
