Sneak Peak.....
Old Apr 9, 2008 | 07:19 PM
  #31
UNV-IT46's Avatar
UNV-IT46
Originally Posted by GiGGaplease
it may seems like you are going faster but the speedo will read like 57.
here is another example. taller side wall means a slower reading. shorter side wall means faster reading...
My OEM goodyears are getting a little worn. I happen to have some 195/60/R15 Yokie ES100s on hand. I would be replacing the stock 185/60/R15s.
In relation to the new size, the tire calculator says:
"Speedo reading is 2% to slow. when speedo reads 60 mph actually traveling 61.2 mph
Old Apr 9, 2008 | 07:26 PM
  #32
UNV-IT46's Avatar
UNV-IT46
copied from miata.net tire calculator.
oem tire 245/40/19
new tire 275/30/19
Speedometer reading with non stock tire is 4.6% too fast
When your speedo reads 60mph, you are actually traveling 57.3mph
I didnt even bother doing the front since the rear clearly show my point
ModBargains.com
Wheel & Tires
Mar 23, 2014 05:15 PM
GetYourWheels
Nov 11, 2013 11:51 AM
NiceG37s
Picture Share G Coupe
39
May 7, 2012 11:55 AM
RAVSPEC
Mar 17, 2012 01:24 AM
