looking at buying track wheels
Old Feb 27, 2008 | 11:13 AM
ten94skyline's Avatar
ten94skyline
i have a friend that is selling his 07 350z wheels for $300, 2 with tires, 2 without. its a good deal but im not sure if they will fit. i read the thread 'widest rear tire' and it was said that the nismo rims should fit. so does that mean the stock z rims should fit also? im not concerned about looks. they will be strictly track/ drift wheels. i dont care if they stick out really far from the rear or any of that, as long as they dont rub too much. im also doing springs and would like to know if they would still fit while lowered. im prepared to do a camber setup and to roll the fenders.
thanx in return.
Old Feb 27, 2008 | 11:25 AM
GiGGaplease's Avatar
GiGGaplease
what are the specs on the wheels? if you do not care if they stick out, then get it. they probably will clear the brakes. how much drop are you looking for? if nothing crazy, then it would not rub.
Old Feb 27, 2008 | 11:34 AM
ten94skyline
not sure on the specs, about to look them up. looking at tein S-techs because thats what ive always used but they drop it pretty low. but if need be i will only put them on the front, i did that with an m3 i had because i put crazy wide rear tires and they rubbed with the springs on the rear, so i only dropped the front and it didnt look bad, and didnt handle any different. and isnt that what fastintentions has? or does he have coilovers but with the rear raised?
Old Feb 27, 2008 | 11:38 AM
GiGGaplease
teins s-techs is going to be low, but i do not think its going to rub your tires or anything. if the tires are wide, then maybe.
Old Feb 27, 2008 | 11:42 AM
ten94skyline
5 x 4.50 or 5 x 114.3 is the bolt pattern and the offset is 30..... think they might fit? still not sure on the brand of springs. g35 springs also fit dont they? looking at tein, h&r, and eibach. all my friends recommend eibach. i will probably put slightly wider tires on the rear but i will see how they fit first. like i said, 2 with tires, 2 without. i think the tires are stock.
Old Feb 27, 2008 | 11:44 AM
ten94skyline
this is the style rim im talking about, for track rims they shouldnt look too right? i cant really even imagine them on the car lol
Old Feb 27, 2008 | 01:30 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
fenders are already rolled on the G37 right?
news1213
Dec 16, 2015 11:06 AM
james6980
Oct 9, 2015 01:28 PM
