Volk GT-Cs w/24mm offset on a G37?
Old Feb 24, 2008 | 02:53 PM
Buddy Revell's Avatar
Buddy Revell
Smile Volk GT-Cs w/24mm offset on a G37?
Was wondering if the rims on my 35 will fit a 37 that isn't dropped?
Fronts are 19x8.5 and rears are 19x9.5. Offset is 27 in the front and 24 in the rear.
Old Feb 24, 2008 | 05:03 PM
LightningG37's Avatar
LightningG37
Well, if you have sport wheels, your looking at the front sticking out 19mm further (.75").
In the rear, You'll stick out and extra 32.25mm (1.27")
I would think this would fit fine, but I'm no expert.
Old Feb 25, 2008 | 11:59 PM
GiGGaplease's Avatar
GiGGaplease
they will fit, but stick out. need to do some fender work.
Old Feb 27, 2008 | 07:32 PM
DKang80's Avatar
DKang80
i have a 20x10.5 +34 mm offset on my g37 tucking tire
Old Feb 27, 2008 | 10:35 PM
GiGGaplease
if so, then they should fit. 9.5 +24 and 10.5 +34 would fit exactly the same, am i correct?
Old Feb 27, 2008 | 11:09 PM
LightningG37
9.5/2=4.75-.95(24mm)=3.8"
10.5/2=5.25-1.34(34mm)=3.91"
so almost exactly. Again, I'm no expert but I believe the drop has something to do with fitment too, i.e. if the drop causes a little negative camber it would actually help the fit. I have seen pics of DKangs car b/c its one of the cars that made me choose the GTCs and I believe his rear neg camber helps those huge 10.5s fit with no rubbing...?
Old Mar 11, 2008 | 03:17 AM
Buddy Revell
I'm kind of a newb when it comes to wheel offset, but can you explain why you divided by 2 when coming up with your measurements?
Old Mar 11, 2008 | 03:41 AM
TerribleONE453's Avatar
TerribleONE453
the front rims are narrower so he decided to go with a different offset to have an aggressive fitment in the front and rear..
Old Mar 11, 2008 | 04:12 AM
Buddy Revell
Anybody recommend a place in So Cal (preferably in OC) to do the fender work?
Old Mar 11, 2008 | 06:23 AM
LightningG37
The numbers I came up with were how far the wheel would stick out from the hub. Offset is how far from the center of the rim the mounting surface is. If you had zero offset on an 8 inch wheel, the mounting surface would be right in the middle and the wheel would stick out 4" from the hub. If your offset was 1", the wheel would stick out 3". Make sense?
Old Mar 11, 2008 | 06:32 AM
LightningG37
BTW, I'm running 8.5/26 front and 9.5/22 rear, so your rears should fit easier than mine.
Old Mar 11, 2008 | 07:17 AM
GiGGaplease
dude, that is just sick.
Old Mar 11, 2008 | 08:10 AM
Buddy Revell
Thanks for the info, Lightning. Your car looks great, by the way!
Old Mar 11, 2008 | 11:14 AM
Protein Shakes's Avatar
Protein Shakes
Yeah, your car looks awesome!.
Love your combo
Old Mar 11, 2008 | 11:28 AM
LAZY TURBO's Avatar
LAZY TURBO
it looks like the guy in the first pic is looking at your in astonishment
