My tirerack.com pricing..
Old Nov 25, 2007 | 05:30 PM
rrrevin's Avatar
rrrevin
Qty Size and Description Availability Price Each Total Price
4 225/50HR-18 Bridgestone Blizzak LM-25 In Stock $179.00 $716.00
4 18x8 ASA JH3 Silver In Stock $139.00 $556.00
4 DCNUT In Stock $3.50 $14.00
4 NISJK00A In Stock $87.00 $348.00
4 Mount and Balance (No Charge) N/C N/C
Shipping: $235.22
GST: $101.40
HST: $.00
PST: $.00
Duties: $105.20
Brokerage Fee: $40.00
Excise Tax: $.00
Provincial Tire Fee: $16.00
Order Total Including Shipping: $2,131.82
Why tirerack? Simple; I wanted Blizzaks. I called around locally and the shps all around Calgary wanted $350.00 PER TIRE! Yes, per tire. I've swaped out summers and winters for 16 years now on my 1991 Corrado, so I'm very used to tire changing. I wanted tires on rims, and I figured since the G37 already has the TPMS, I'd get that as well. The same setup in Canada would cost me over $3000.00.
The tires fit perfectly. Hint: leave the yellow centering ring IN.
I'll post pics later.
Old Nov 25, 2007 | 05:43 PM
shumby's Avatar
shumby
not bad I got 4 michelins pilot alpins 245/45 18 rims and sencors installed for the same price 2100 and change.
Old Nov 25, 2007 | 05:45 PM
bostonmerlin's Avatar
bostonmerlin
agree my winter tires/rims came in a month or so back.. did my first install this morning. about an hour start to finish.. though the low profile floor jack saved time lifting the car. Total cost was around $1,900 and that includes shipping, tps sensors and tire bags.
Overall the tirerack experience was very good.. tires were shipped within a few days and packaged up very nice for delivery. instructions were easy enough.
Old Nov 25, 2007 | 07:28 PM
Comatose's Avatar
Comatose
rrrrev, cant wait to see the pics I have the same on order but without the TPMS.
Hoping to throw some custom centercap decals on it as well!
Old Nov 25, 2007 | 08:10 PM
PSYH's Avatar
PSYH
Post Whore
How does one change tires/wheels that is equipped with TPMS?
Old Nov 25, 2007 | 08:40 PM
rrrevin's Avatar
rrrevin
Each TPMS sensor has a unique ID than must be registered to the computer in the car. The car computer will be still looking for the old sensors. I have to take the car to a dealer, pay him a few $$$ and they will re-register the new sensors to the car.
Old Nov 25, 2007 | 09:09 PM
rrrevin's Avatar
rrrevin
pics..
OK here are some pics.
I bought a floorjack to do this. For the front tires I put the floor jack just on the opposide side of the "hoist notch markers".
In floorjack1, you can see that I've put the jack to the side of the car, not in the front or the back. The jack will not slide under the front, it's not low enough.
In floorjack2, you can see where I put the jack. This view is looking "up" towards the jack form the ground. The front of the car in floorjack1 and floorjack2 is to the left.
In wheel1, this is with the summer tire off. You can see the 5 regular bolts + 1 special bolt. This must be removed before you can put on your winters, and should probably be put back on when it somes time to put on your summers.
In wheel2, this is the same as wheel1, except with the special bolt removed.
In floorjack3, this is the rear tires. I put the jack slightly behind the notchs and again on the other side of the notch marker itself. There is a metal support with a hole in it that supports the car perfectly. You can't miss it.
Attached Thumbnails My tirerack.com pricing..-floorjack1.jpg   My tirerack.com pricing..-floorjack2.jpg   My tirerack.com pricing..-wheel1.jpg   My tirerack.com pricing..-wheel2.jpg   My tirerack.com pricing..-floorjack3.jpg
Old Nov 25, 2007 | 09:13 PM
rrrevin's Avatar
rrrevin
pics cont
In wheel3, before I mount the tire on the wheel, I always spray the bolts will WD40. This helps loosen them months down the road when it comes time to take them off. I hold a paper towel under them to catch any excess spray that drips down.
Some hints:
You'll need paper towels, WD40, a decent tire wrench. Leave the yellow centering ring on from tirerack when you mount the tires. This really helps center the wheel. If you take it off, your tire will probably be off center and hence off balance and will cause vibration when you drive. Took me about 2 hours this time around as it was my first time with the G (I normally do all 4 tires on my Corrado in 35 to 40 mins). Most of the time was spent looking for the right place to put the floorjack, and reading instructions. In the summer I'll probably be able to get this down to my normal time.
Old Nov 25, 2007 | 09:16 PM
PSYH's Avatar
PSYH
Post Whore
Oh gosh, it's so dirty already. That's Canadian winter for ya...
Old Nov 25, 2007 | 09:18 PM
rrrevin's Avatar
rrrevin
finished product...
After all is done.. this is what you end up with...
Old Nov 25, 2007 | 09:19 PM
rrrevin's Avatar
rrrevin
Actually, this is the dirt from the delivery. I washed it after putting the winter tires on.
Old Nov 25, 2007 | 09:21 PM
PSYH's Avatar
PSYH
Post Whore
Oh.
Old Nov 26, 2007 | 12:35 AM
Comatose's Avatar
Comatose
nice!! any pics of the entire car w/ the rims on? im interested to see how the overall package looks
Old Nov 26, 2007 | 01:15 PM
Orbie's Avatar
Orbie
I think the Sport Edition A7's that some of us went with for $99 are a knock off of those ASA ones, as they look almost identical. Anyways, did you receive centering rings with those? I'm just curious what the size was on those rings. When mounting my winters I noticed that the centering ring did not fit perfectly on the car hub. I bolted the rims on thinking it would force the rings on the hub, but it just appears to have pushed the rings on as much as possible, I still don't think they are flush. I'm hoping they didn't send me one size to small.
Anyone mounting the ASA's or A7's want to chime in?
Also did anyone notice that the offset on these rims push the rim out? I actually like the look of the wheels pushed out further, I wish that was the case with the summers. Much more aggressive filled out look, too bad the rims don't look anywhere near as good as O.E. 19's.
Old Nov 26, 2007 | 01:28 PM
shumby's Avatar
shumby
Nice wheels rrevin better than my winters i think.
