Sponsor New forgestar wheels cf10, taking orders now
Old Oct 4, 2011 | 12:23 AM
Lou@Amplified's Avatar
Lou@Amplified
Forgestar's Rotary Forged Flowforming process is a unique solution to a common problem – how to make a wheel both light and strong.
This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction.
This grain structure pattern, combined with the exceptional quality of casting required for the process, gives the rim area of the wheel huge mechanical strength, and elongation. As a result of these mechanical characteristics, Forgestar is able to reduce the thickness of the rim area resulting in reduced weight, without compromising strength and resistance to impact.
AVAILABLE SIZES
20X9 +25 to +35
20x10.5 +12 to +46
5x114.3 bolt patters
Most colors available. These are made to order so you can request colors with order before they get powdercoated.
I know some people from the past had problems with orders but i guaranty now that these are made from manufacturers as "blanks", cut and drilled here in the united states to fit bolt pattern and offsets, then powdercoated here. They have the blanks in stock so wait time is only 3-4 weeks. I will check inventory prior to taking your order
PM ME FOR PRICING
thank you
Lou
Old Oct 4, 2011 | 03:15 PM
Lou@Amplified
I forgot to mention that 20x10.5 weighs only 22.5 LBS
G's
Nov 5, 2023 12:01 PM
WolfSongX
Car Care & Detailing
May 10, 2017 07:26 PM
james6980
Oct 9, 2015 01:28 PM
pledes23
Aug 11, 2015 10:54 AM
350zrunnin12s
Aug 9, 2015 09:55 PM
