Special Enkei RPF1 Light Weight Racing Series Wheels
Old Mar 24, 2011 | 01:56 AM
JEBperformance's Avatar
JEBperformance
Weight ranging from 17 lbs. to 21 lbs. RPF1 by Enkei racing, a perfect choice to add performance and achieve look you always wanted for your G37.
enkei for being MacLaren Mercedes F1 Team sponsor, incorporated same technology and design through their F1 team efforts.
enkei always strives to give best performance at reasonable price. That is why JEB Performance decided to bring world class, light weight, enkei wheels to MYG37.
Does weight matter? YES weight on a wheel is critical aspect on your car performance. Our OEM 19x9 wheels weighs 27.5 lbs. On enkei's 19x10.5 the weight is reduced to 21 lbs. Less weight means less torque required to turn your wheels. Also wheel and tire will weigh much more at greater speed. Exponentially so at average 55mph due to centrifugal force exerted, your wheel will weight three times compared stationary weight. Demanding more torque to be generated by your engine. Achieved through Enkei's Patent Pending MAT Technology.
We will offer only the offset and wheel size recommended from enkei. As you know at very very reasonable price Only from JEB Performance.
Front Setup
  • Enkei 19x9.5 front wheels, 1" wider than than our stock wheels.
  • Offset is 42mm compared to 43mm stock wheels.
  • 11mm deeper, and 13mm closer to the fenders. For stability and traction.
  • Weighs 20.3 lbs. compared to Stock wheels 27 lbs.
  • Recommended tire size 245/40/19, tire diameter will be less 6mm.
Rear Setup
  • Enkei 19x10 rear wheels, also 1" wider than stock wheels.
  • Offset is 22mm compared to 45mm stock wheels.
    • 11mm shorter, and 35mm wider toward the fenders. For stability and traction.
  • Weighs 21.3 lbs. compared to Stock wheels 30lbs.
  • Recommended tire size 275/35/19, tire diameter will be less 4mm.
MSRP $2120 JEB PERFORMANCE ALWAYS SUPER LOW PRICE FOR THE FIRST 10 CUSTOMERS ONLY $1600 WITH FREE SHIPPING. ONLY AVAILABLE IN FORMULA SILVER.
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
Old Apr 15, 2011 | 01:29 AM
JEBperformance
lighter MAT technology
Old Apr 15, 2011 | 01:40 AM
LizardBreath's Avatar
LizardBreath
enuff bumps at once jesus
Old Apr 15, 2011 | 02:32 AM
J2S2M's Avatar
J2S2M
Wow, this is a great price John! This would be a great pick up as a track setup. I wish the offset on these were a lil lower in the front and higher in the back though. Are these the only offsets available at this price?
Old Apr 16, 2011 | 10:26 PM
iwasgointo's Avatar
iwasgointo
I'm interested, but can I go with the 42mm offset for the rear also? I don't want to bring the rear tires out that far toward the fender lip. Also, the center bore of the Enkei wheel is 73mm while the center bore for the oem wheel is 73.1mm. Will this present a fitment problem?
Old Apr 19, 2011 | 08:21 PM
JEBperformance
For track use, consider 18" wheels. I ordered NT03+M's ETA July 2011. The best for track use.
18x9.5 +27 offset front
18x10.5 +30 offset rear
Also you can order Nitto NT01 tires with above setup. For best track use.
Sorry they do not make 42mm rears. Please visit Enkei Wheels website for best racing wheels. And PM us for best price.
Old Apr 28, 2011 | 08:54 PM
JEBperformance
Most Advanced Technology
Old Apr 29, 2011 | 04:10 AM
myk1013's Avatar
myk1013
Do you have any pics on a G coupe? These specs clear the Akebono brakes right
Old Apr 29, 2011 | 12:38 PM
JEBperformance
I will post some pictures on July, they are backordered with Enkei. Yes they will clear Akebono brakes.
Old May 3, 2011 | 01:03 PM
JEBperformance
Tuesday BUMP
Old May 6, 2011 | 01:14 PM
JEBperformance
All of us @ JEB wishes you a wonderful Weekend.
Old May 12, 2011 | 11:12 PM
JEBperformance
Thursday Night BUMP
Old Jul 26, 2011 | 06:52 PM
JEBperformance
light weight more HP gains to your rear wheels. Front more grip, since less travel
Old Jul 29, 2011 | 07:01 PM
JEBperformance
ENKEI Weekend Special, PM us between Mid Night July 30, 2011 and July 31, 2011. We will get back to you with special promotion price. Thank you for the opportunity.
Old Aug 1, 2011 | 04:00 PM
JEBperformance
Thank you for all your PM inquiries over the weekend. All PM replied.
