TSB - Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
headlight recall on 09
Old Apr 17, 2011 | 07:59 PM
AZg37's Avatar
AZg37
is it moisture or physical damage?
Old Apr 18, 2011 | 06:25 AM
Silver37's Avatar
Silver37
It looks like it's melted slightly in the same place in both - like I have another unplanned lens. Also have some discoloration above one turn signal. All on the inside.
Old Oct 29, 2015 | 10:05 PM
R35sedan's Avatar
R35sedan
R35SEDAN #4
From: In NJ, Hunterdon County Equally far from NYC and Philadelphia
Maybe this is a coupes thing but either way I highly recommend you don't even waste your own time trying to swap bulbs and or do any customizing unless you have plenty of room in a heated garage, I did A full swap to 6000k bulbs answer turned my front signals and fog lights using those 1140k xml2 led bulbs were ever i could. The xml2's are awesome for both adding to your normal front view much wider and the hid bulbs are honestly more than I expected for the price. It took me forever because I stubbornly choose not to fully drop my bumper, course that doesn't really work when you're doing themy in the verge of several holidays and cold Temps headed to the north eastern US. But either way I am still a fan of Diode Dynamics and the more expensive bulbs truly are worth it. Happy to offer tips to help you out and if you are a central Jersey resident message me since I don't mind helping out. This is my 4th G car and I am actively seeking 2 others, a blk on blk IPL 7spd coupes and and any older versions preferably with some body damage or blown motor as side project. Take care. Thanks for the input.
2K1 6T8
Oct 6, 2015 07:40 PM
Allboutcali
Sep 26, 2015 03:43 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
TVPostSound
General Tech Questions
Sep 2, 2015 04:09 PM
