M56 vs M37
M56 vs M37
Wanted to ask which one would you choose if you had a choice. Any color, trim, etc. Would you go with the M37 or the M56? The 3.7 liter V6 or the 5.6 liter V8?
I'd personally go with the 5.6 variant since you don't see them too often and they're kind of like unicorns. Not a lot of people know about them either. Like they say there's no replacement for displacement!
Everything I read is that performance-wise you're better off overall with the 3.7. The 5.6 though has more power and though quick is not much quicker but considerably more nose-heavy. I'm more a performance person so I'd want it to handle well. I agree though that the 5.6 is rare and not well known about.
Yes, when I was looking for my M, several articles I read said they liked the way the 3.7 felt over the 5.6. The 5.6 just felt to heavy and that the 3.7 was plenty of engine for the type of car it is. Maybe a compromise would be get the hybrid. That configuration has some pretty decent 0-60 numbers for a heavy 4 door sedan.
I'm right there with you but assuming the most you do is bolt-ons, the 3.7 isn't going to be quicker; and if it is it'll be negligible. The 5.6 is rated at 400hp and tq so the muscle is there. That said, the 3.7 is probably the more high revving motor if the 5.7 is tuned like it is in the Titan. Regardless, custom exhaust on the 5.6 sounds awesome and it has all the straight line power you'd need. If OP goes with (or went with) this, just realize, as you mentioned, it's going to be heavy up front.
It's not that big of a difference with the 37 being 54/46 and the 56 being 56/44. In my opinion the only reason I see a lot of people in the M37s instead of the M56s is because they can't find an M56 or can't afford an M56. The M37 just seems like an over sized G37 and not that sporty. The M56 felt just how an M is supposed to feel like, a big rocket ship that'll take me to Mars. The VK56 in the M56 has 420 HP with 417 lb/ft of torque as opposed to the QX80/QX56 VK56 which is tuned to 400 hp and 413 lb/ft torque. The hybrids are not worth it unless you REALLY care that much about the environment and 0-60, however the service on those hybrids are a PITA especially when the lithium batteries do eventually break down.
You guys got to be kidding me with the weight distribution. None of you will be taking it to a circuit track, Jesus Christ everyone thinks the change of weight distribution will make them a Michael Schumacher
It's not that big of a difference with the 37 being 54/46 and the 56 being 56/44. In my opinion the only reason I see a lot of people in the M37s instead of the M56s is because they can't find an M56 or can't afford an M56. The M37 just seems like an over sized G37 and not that sporty. The M56 felt just how an M is supposed to feel like, a big rocket ship that'll take me to Mars. The VK56 in the M56 has 420 HP with 417 lb/ft of torque as opposed to the QX80/QX56 VK56 which is tuned to 400 hp and 413 lb/ft torque. The hybrids are not worth it unless you REALLY care that much about the environment and 0-60, however the service on those hybrids are a PITA especially when the lithium batteries do eventually break down.Take a stock G37 RWD coupe around a corner at 10+ the speed limit then do the same in the x model and tell me you don't approach that corner differently...
M56x all day. I actually see two on my way into work pretty often. I still like the G styling more, but would love that engine.
200+ pds up front will in fact make a difference in the handling characteristics of a car...regardless of your driving style.
Just cause you have a slightly better weight distribution won’t make the car feel anymore balanced or any faster. It’s all about the drivers skill, so don’t try and kid yourself you’ll be the next Senna with a better 54-46 distribution than 56-44. Better yet learn how to drive if it’s a such big deal.
Now if the feeling is a big deal, then it’s worth it to change the suspension a bit so it handles better. Maybe make it feel more planted. The Skyline R32s weren’t 50-50, more like 59-41 and smoked the **** out of perfect 50-50 machines like the RX-7, both in stock form. I thought you guys were joking about the weight distribution but now that you guys confirm it’s a big deal I’m kind of interested to know what you guys are feeding on
My vote is for the 5.6 liter V8 but maybe thats just me...the M(now Q70) in long wheelbase form is #3 on my list of 3 potential replacements for my G so I've looked at them closely...for me the 3.5/3.7 L VQ is fine for the G chassis but it would feel way under power for me in the Q70 chassis... from what I can tell the aftermarket sucks compared to the G/Z cars but you can get better sway bars which should help with the handling...but even with suspension tweaks I found the steering to be too soft to really want to take it around corners really aggressively (Mind you I'm talking about the Q70L which is longer and even less suited to corner carving) its more of a comfortable cruiser with a nice punch when you want it
Have you ever driven the X? It has body roll like a pig and under steers something horrid. Sway bars, rubber and, at the minimum, springs are required before it has any resemblance of neutrality. I think your glamorizing the AWD capabilities a bit much in your R32 example; the G37x has almost 1k pds on the R32....Not to mention its suspension is no where near the race oriented R32...
The X also has open differentials at both ends, not an LSD like the RWD S Coupe. In stock form, the RWD coupe is the better handling of the two when it comes to any type of fair weather driving. 'Driver mod' has nothing to do with it. You put equally talented drivers in those cars and the sport oriented RWD coupe will out perform the X.
Edit: Think about what you're saying for a second....A g37 coupe (and 6MT Sedan for that matter) is basically a dressed up Z car. Do you really think the non-sport oriented, toned down, family sedan version of the G37 is actually a better handling car than the sport/track focused 370z?
VK56VD is 496 lb and the VQ37VHR is 350lb. About 150lb difference. Why do you guys care so much about weight distribution when most American males weigh around 200 lbs? If people are concerned about the weight distribution being messed up then they got to get off the forums and lose some weight and then get the 5.6.
The S trim is basically dealer marketing that only comes with a slightly tougher suspension and bigger brakes which aren’t necessary since you can still take corners with a journey easily. The LSD is more focused for a track car not a street car where you won’t be taking corners like a formula 1 car. No extra horsepower from the S, kind of like a Corolla S. I barely felt a difference when I drove an S and a Journey, almost felt the same with the S having a slightly more bumpy ride. Cool bumpers on them though. Don’t understand the praise of an LSD for daily driving, but can’t lie that they are fun when going around tracks.
Please tell me you’re joking how a RWD model can outperform an X model. The all wheel drive system just grabs onto the road like there’s no tomorrow. If you think an LSD on a RWD can outperform and open diff AWD that’s crazy talk. In real world driving, not Nurburgring style, you can very much throw the X model into any corner with full throttle and it will take it like a champ with or without an LSD. A RWD model, S or not S, is more difficult cause you can spin out with full throttle even with less weight compared to the X.
And the R32 had inferior suspension with a lot of body roll but still beat a lot of lower weight, 50-50 weight cars. And the weight difference is about a 600-650 lb compared to a G37X, not a thousand. Also good to remember the chassis is more stiff in the G37 than an R32. Same exact AWD but the 32 came with LSDs.
Now if they put the VK56 into the G, that would be awesome. G56
I will agree with RMB5190 as long as we are talking stock. The second you look at modifying both drive-line and suspension in the two the X will outperform. Brake limited slip with mechanical LSD and an apples to apples suspension upgrade for the two and the X will outperform.
The X is only 214 pounds more than the non-X and that weight is low down, 50% behind the front axle, and 50% at it; it's not that bad. The fact that it was set up as a winter northern warrior is why it handles like crap from the factory, IMO.
EDIT ADD: "A g37 coupe (and 6MT Sedan for that matter) is basically a dressed up Z car." LOL, if we are calling 319lbs dressed up then the G37x is a tarted up harlot version of the G37.
X feels more planted around the corners and you can floor it around while with a RWD you can spin out if you give it the beans.
