I have a wierd idle
Old Jul 12, 2007 | 10:42 AM
6MT G-STYLE's Avatar
6MT G-STYLE
I have a wierd idle
Ok I was trying to be a good teamate so me and Ronnie switched spacers so ronnie could put his stock strut bar back on his 350Z...I gave him my Mtrdyn 5/16 and ge gave me his AAM angled spacer...I intalled the spacer last night and the car runs perfect and everything except at idle...it will idle at about 750-800 rpm which is what it was idling at before w the 5/16...but every 30 seconds the rpms dip down to about 600 and the car almost dies...the computer will self adjust and the idle goes back up to 750-800...I left the battery disconnected overnight...any ideas on how to fix the idle? I double check all bolts and hoses and everything appears to be in order...
Old Jul 12, 2007 | 10:56 AM
G Thizzle's Avatar
G Thizzle
$up3rch@rg3d Vq35
have you tried resetting the ECU using the foot dance method??? Im not sure if disconnecting the battery clears the ECU completely... just my.02
Old Jul 12, 2007 | 10:59 AM
rob350's Avatar
rob350
i think the computer just has to relearn. i dont think its anything big. make sure your battery is good. my battery f@wk up my butterfly position and was making my car run super lean and stall out. so i had to get a new battery and get my throttle position retuned. my car idles real low due to my clutch and flywheel.
Old Jul 12, 2007 | 11:07 AM
6MT G-STYLE
No I havent...it that the deal that came w the Mtrdyn pprwrk?
Old Jul 13, 2007 | 01:32 PM
6MT G-STYLE
Well I tried to reset my throttle body w the instructions off of Motordyne but I just can't do it...I can't get the cel to blink...it just comes on and stays on when I depress the accelrator 5 times w/in 5 seconds...Devin, I need your boy to set it for me asap please!
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
vamarris
Dec 9, 2018 11:10 AM
the dreame
Apr 9, 2017 10:30 AM
