Supporting Vendors Products and services, available for purchase from registered vendors.
>>>>PLX Gauges | The new gauging sensation<<<<<
Old May 24, 2008 | 12:30 PM
THMotorsports's Avatar
THMotorsports
Thumbs up >>>>PLX Gauges | The new gauging sensation<<<<<
Innovative great design. Take a look!.
DM-100
Intelligent Multi-Functional Display (iMFD)
Universal 2 1/16" (52mm) OLED Color Display for all Sensor Modules
* Real Time Plotting
* Customizable Gauge Styles, Backgrounds and Colors
* Digital Display
* Organic LED
* Set Peak and Hold Points
* Can Display Data from 4 Modules at Once
* Daisy Chain up to 32 Sensor Modules for One Display
* Simple to Install
* PC Interface Software Included for Analyzing Data
* Comes with Remote Control
WATCH IMFD VIDEO: CLICK TO WATCH
DESCRIPTION:
The iMFD DM-100 is a 52mm (2 1/16") universal gauge designed specifically to display a wide variety of automotive information far superior to that of a standard automotive gauge. The DM-100 can display up to 4 different sensors simultaneously and can be connected in a daisy-chain with up to 32 sensor modules and 32 other display modules.
KEY FEATURES:
1. Color Organic LED Technology (OLED)
2. 180 Deg Viewing Angle
3. High Contrast, Daytime visible
4. Multiple gauge styles (gauge, numeric, plot, 4 param, x-y scatter, custom)
5. Peak and hold (4 parameters, high and low)
6. Intelligent warning (4 parameter comparison)
7. Custom gauge design
8. 4 button remote
9. Daisy chain topology
10. Custom wallpaper upload
11. Automatic sensor detection
12. Extruded aluminum construction
STANDARD GAUGES:
Unlike other automotive displays on the market where the user has no choice but to view data presented only in one form, the DM-100 has the capability of displaying data in multiple forms. As seen above in the state diagram, each parameter can be viewed in a gauge style, a numeric style, a plot style, and simultaneously in the 4 parameter style. Each style offers its unique advantages.
The plot style is a unique feature in automotive displays. Now data can be viewed as a trend, instead of just it's instantaneous value. This gives the user quicker access to information without the use of a data logger.
Some additional user customizations are also available in the standard gauges. Colors can be customized, and background wallpapers of your choice can be uploaded from the PC making each gauge unique to your own taste.
CUSTOM GAUGE:
The custom gauge design is one of the many unique features found on the DM-100. In state 1-4, the user has the absolute freedom to design your own gauge on the PC and upload it to the DM-100 via USB. You will have full control over every pixel, every pixel color and every displayed frame. It's only up to your imagination what you want to design and display to represent your automotive sensor data. You may also visit our Custom Gauge Library where you can download already made custom gauges.
PEAK AND HOLD:
The user can set the DM-100 to remember both high or low values for each parameter. Peak values can be viewed in state 2-3 and can be reset on command at any time.
INTEGRATED WARNING:
1-4 parameters can be setup to trigger a warning condition. When a warning is triggered, the parameter's value will be displayed on the screen giving the user immediate information. Multiple warning schemes are available. This feature can prove to be extremely vital in monitoring the health of your vehicle.
TECHNOLOGY:
The DM-100 employs several new patent pending technological breakthroughs in digital design. At the core of this technology is a 32 bit CPU coupled with a PLX designed GPU (graphics processor unit). Just has high end video graphic cards are designed for PC games, the PLX GPU was designed specifically for automotive display applications, making the OLED color display possible at an affordable price. Ram, flash and USB technologies are also incorporated.
INCLUDED ITEMS:
1.DM-100 Module
2.HDD-100 52mm Universal OLED Display
3.6ft 4 button remote
4.4ft power wire with 2.1mm connector
5.1ft Serial Cable
6.6ft USB Cable
7.CD includes User Guide, DM-100 Utility, USB Device Driver
8.Comprehensice User Guide
SPECIFICATIONS:
Physical Dimensions (Box) 4" x 2.875" x 1.125" (104mm x 75mm x 28mm) L x W x H (TINY!!!)
Physical Dimensions (Gauge) Standard 2 1/16" (52mm) x 0.7" (18mm)
Power Consumption 1.5 Watts
Compatible HDD HDD-100
Processors Custom PLX 32 Bit Processor, Custom PLX GPU (Graphics Processor Unit)
Operating Temperature 0 - 85 Deg C
Operating Voltage 10V-18V
Automatic Sensor Detection YES
Human Interface 4 Button Remote
PC Interface USB 2.0
# Sensor Modules 1-32
Firmware Upgradeable Yes
Enclosure Extruded Aluminum
PLX iMFD DM-100 Gauge + SM-AFR Wideband O2 Sensor
Order Link:$395 Shipped http://thmotorsports.com/plx-devices.../i-156853.aspx
Other Modules:http://thmotorsports.com/plx-devices...e/g-53995.aspx
SM-AFR
Sensor Module - Air/Fuel Ratio
Digital Wideband Air/Fuel Sensor
DESCRIPTION:
SM-AFR accurately measures the precise air/fuel ratio (AFR) of any internal combustion engine. Up to 32 SM-AFR modules can be daisy chained together in the iMFD system. SM-AFR can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
SM-EGT
Sensor Module - Exhaust Gas Temp
Digital EGT Sensor
DESCRIPTION:
SM-EGT accurately measures the exhaust gas temperature or cylinder head temperature of any internal combustion engine. Any K-Type thermocouple is compatible. Up to 32 SM-EGT modules can be daisy chained together in the iMFD system. SM-EGT can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
SM-FluidTemp
Sensor Module - FluidTemp
Digital Fluid TempSensor
DESCRIPTION:
SM-FluidTemp accurately measures the the temperature of any liquid. This is ideal for coolant temp, transmission temp, oil temp and any other fluid temp monitoring. Up to 32 SM-FluidTemp modules can be daisy chained together in the iMFD system. SM-FluidTemp can also be used as a stand alone unit capable of interfacing with 3rd party hardware. All Sensor Modules are housed in high quality extruded aluminum designed to operate even in the most extreme conditions. In addition, all SM modules offer outstanding digital accuracy, response and resolution which far exceeds that of a standard gauge.
Call 1-800-959-0145 ext 2 toll free and mention the sale
**Master Card, Visa, Discover, AMEX** OR PM US!!!!!!!
Old May 26, 2008 | 12:49 PM
THMotorsports
Best bang for the buck
Old May 26, 2008 | 05:51 PM
TerribleONE453's Avatar
TerribleONE453
only if we had a A pillar pod that fit
Old May 26, 2008 | 09:56 PM
vINCe_Inc's Avatar
vINCe_Inc
awesomeness.
if you had money, you can create a jumbo-tron with those in your car !
Old May 27, 2008 | 01:17 AM
UNV-IT46's Avatar
UNV-IT46
yep thats what i'm waiting for. I have a bunch of Defi gauges waiting to go in. just have not figured out a way to mount them that i like yet
Old May 27, 2008 | 02:11 AM
TerribleONE453
mmmmm defi... good choice!
Old May 27, 2008 | 09:13 AM
UNV-IT46's Avatar
UNV-IT46
only choice for me.
Old May 27, 2008 | 12:06 PM
THMotorsports
Defi is ok, just not my favorite for the price
Old May 27, 2008 | 12:22 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Get us a Triple guage pod made
Bump for a great vendor
Old May 27, 2008 | 02:22 PM
UNV-IT46's Avatar
UNV-IT46
i sell them so the price for me is great lol.
Old May 28, 2008 | 12:44 PM
THMotorsports
Then hook it up haha!
Old May 28, 2008 | 03:35 PM
UNV-IT46's Avatar
UNV-IT46
pm a brotha lol
Old May 28, 2008 | 03:37 PM
Blackjack's Avatar
Blackjack
+1... Need A-Pillar pod ASAP... PLEASE!!!!
Old May 29, 2008 | 01:11 PM
THMotorsports
me too, im waiting on autometer, unless someone knows something that i dont
Old Jun 7, 2008 | 04:16 AM
Mike's Avatar
Mike
Can you PM me a price for the 52mm, AFR, ETG, Oil Pressure, and Boost?
I'm gonna be needing some monitoring hardware, and the multi display is ideal for what I want...
