Convertible 2009-2015 top flaps gears replace
Old May 3, 2021 | 09:46 AM
Guy Menard's Avatar
Guy Menard
Stuck with broken flap on you vert? You're not alone...One of the most common problem known on Infiniti vert's!!!
got machined made metal gear replacement for oem plastic gears. Sold by pair.
easy to diy install in less than hour, no special tools needed except of rivets.
need some? Email me for more infos
: guy.menard305@videotron.ca
Old May 4, 2021 | 06:50 PM
NewG37OwnerAt59's Avatar
NewG37OwnerAt59
What is your pricing for a pair?
Old May 4, 2021 | 07:13 PM
Guy Menard's Avatar
Guy Menard
actual price is 550$usd including shipping with Fedex. ***NEW PRICE IS NOW 500$usd + SHIPPING***
price is for a pair (left and right gear)
Old Apr 11, 2022 | 08:14 AM
travlerv's Avatar
travlerv
I dont see the outer gear. Isnt it that one that brakes? Is there any way you can show a pic tof the assembly part with a broken gear and assembled part with your new gears? It just be nice to see how everything looks. Before & after pic.
Old Apr 11, 2022 | 09:35 AM
Guy Menard's Avatar
Guy Menard
2012 to 2015 oem broken gear
My metal gears (all assemble and ready to replace) for 2009 to 2015 models
2009 to 2011 oem broken gear
Old Jun 13, 2022 | 11:23 AM
Guy Menard's Avatar
Guy Menard
New batch in...Convertible to flaps metal gears for all vert from 2009 to 2015
Ready to ship worldwide.
You can email me directly at: guy.menard305@videotron.ca
Old Apr 14, 2023 | 05:18 PM
MarkB's Avatar
MarkB
Request info on purchasing gears
Mr. Menard,
Requesting info on gears for a 2014 Q60 IPL Convertible.
Looking forward to your response.
Thank you
Regards,
Mark B.
New Orleans
mibarch@gmail.com
Old May 25, 2023 | 08:23 AM
travlerv's Avatar
travlerv
Originally Posted by MarkB
Mr. Menard,
Thank you
Regards,
Mark B.
New Orleans
mibarch@gmail.com
Do you have a link that shows a step by step for the whole procedure? I have a 2012 G37 vert.
Old May 25, 2023 | 08:25 AM
travlerv's Avatar
travlerv
Old May 25, 2023 | 08:37 AM
Guy Menard's Avatar
Guy Menard
Installation instructions are include when purchasing the gears.
...You can also check on YouTube, there are 2 or 3 clips showing how to install.
if you're in need for gears or more infos, you can contact me directly at: guy.menard305@videotron.ca
Guy Ménard
Old May 25, 2023 | 08:42 AM
MarkB's Avatar
MarkB
See link from Guy Menard below.
Old Jun 8, 2023 | 04:14 PM
LuckyJack's Avatar
LuckyJack
Hi Guy,
As mention in the other thread, I received the flapper gears a couple days ago and have started working on it today. So far I've got the trunk liner off, removed the plastic cover and the motor.
I do have 1 questions though: in removing the rivet that holds the cover down, the head of the rivet came off and the cover came off, but there's a large piece of rivet still in there that I have not been able to get out. So, my questions are: 1. what width of drillbit do you recommend using? Maybe I used too narrow one. IIRC I used 5/32; and 2. do I need a special type of drill bit made for metal? I am using general purpose bits that don't seem to have the bite they need.
Thanks!
Old Jun 8, 2023 | 06:51 PM
Guy Menard's Avatar
Guy Menard
Originally Posted by LuckyJack
Hi Guy,
Thanks!
Normaly, if you remove the rivet head, you can simply punch out the back of it...it will drop between the 2 layers of the trunk panel ( that you would be able to remove later, after reinstalling, by opening the trunk backward and using a magnet stick insert in holes of the trunk back lid.)
OEM are steel rivets,...harder to drill but, no special drillbit ( a good sharp one will do the job).
Hope it will help...!
Old Jun 8, 2023 | 08:22 PM
LuckyJack's Avatar
LuckyJack
​​​​​​That explains why it was so hard drilling it out...
Thanks, Guy.
Old Jun 9, 2023 | 03:24 PM
LuckyJack's Avatar
LuckyJack
Hi Guy,
I'm basically ready to put everything back together. But before I do, I wanted to ask a question about the grease. The stuff I got, general purpose lithium grease, seems very thin compared to what was in there. It seems kind of light and fluffy, rather than thick and heavy. So I'm wondering, is that going to be OK, or should I clean it out again and get some of the thick stuff...
Thanks,
Paul
