FS 2009 G37S Sedan (AT) Supercharged MotoIQ project car
Old 06-28-2023, 03:39 PM
sootfoot
sootfoot's Avatar
Year: 2009
Make: INFINITI
Model: G37 Sedan
Price: $19500
Mileage: 91500
Color: Moonlight White
Location (State/Prov): AZ
G37Leadshot
For sale is my G37 project car. I’ve owned the car for over 8 years now and have added about 34k miles in that time. It is also a MotoIQ project car with extensive documented history of the modifications performed. Feel free to ask questions here and serious buyers can send me a PM and I’ll do my best to reply within a day. For the sake of saving everyone's time, low ball offers will simply be ignored. The same goes for tire kickers or joy rides, please go elsewhere. Local inspections are welcome as are test drives for serious buyers ready to purchase.
The base vehicle stock is worth $8,900-9,100 KBB private party in Good condition. Without getting too detailed with pricing on the aftermarket parts there’s $26,900 invested there not including labor. Most of the modifications on the car were performed in the MotoIQ garage by Howard, their master technician. The tuning on the car was performed by Sebastian at Specialty Z.
The reason I’m selling the car is simple, it’s time to move on. I’m not trying to hide any hidden damage or time bomb waiting to go off; hence the known flaws section and detailed photos. I’ve owned the car for 8 years and I’ve done everything I wanted to. In due time I’ll purchase another fun car but currently I have other priorities.
Gallery to additional images
YouTubeVideos
For all the super in-depth detail on the project; the MotoIQ articles can be found here:
https://motoiq.com/category/projects/infiniti/g37s/
VIN: JNKCV61E39M014412
Title Status: Clean (AZ)
Engine: 3.7L Supercharged V6
Drivetrain: Rear-wheel drive
Transmission: Automatic (7-Speed)
Body Style: Sedan
Exterior Color: Moonlight White
Interior Color: Stone
Carfax (might stop working anytime now)
Modifications include:
Powertrain:
Vortech V-3 Si-Trim supercharger
SOHO Motorsports air-to-air supercharger upgrade
Fast Intentions cat-back exhaust system, high-flow catalytic converters, and test pipes
Stillen intake manifold, valve cover, boost pulley, oil cooler, and transmission cooler
CJ Motorsports S1.SE fuel system, upgraded fuel pump hat, and fuel pressure gauge
Injector Dynamics ID1050x fuel injectors
Aeromotive 340 Stealth fuel pump, fuel pressure regulator, and 10 micron fuel filter
DeatschWerks upgraded fuel system wiring
UpRev upgraded MAF sensors
Omni Power 4 bar MAP sensor
K&N air filter
EcuTek ECU with 4 programmable maps and Bluetooth adapter for datalogging and map switching
ECU tune by Speciality-Z
NGK spark plugs
CSF Race radiator
Level 10 Products Bulletproof 7-speed automatic transmission
Wheels, suspension, and brakes:
19-inch Advan Racing RZII wheels with Nitto NT05 front and Nitto NT555RII rear tires
KW V3 coilovers
Eibach sway bars
Stillen slotted front and rear brake rotors, front and rear
Z1 Motorsports ceramic front brake pads and power steering hoses
Stillen ceramic rear brake pads
Exterior and interior:
Autometer Elite boost gauge, transmission temperature gauge, oil temperature gauge, and dimmer
Ortiz Custom Pods gauge pods
Ryne re-wrapped steering wheel
Known Flaws
Chips on front bumper
Plugged and touched-up hole in front bumper
Front paint protection film and driver's side headlight turning yellow
Touched-up scratches on clear coat on driver's door
Ding on driver's side rear fender
LED on gauge cluster intermittently goes out in extreme hot weather
Outdoor temperature sensor reads high due to supercharger system
AutoMeter transmission temperature gauge reads higher than the factory gauge
Turn signal noise does not work (indicators still work)
Passenger Front
Passenger Side
Passenger Rear
Rear
Driver Rear
Driver side
Driver Front
Passenger Seat
Rear Passenger Seat
Rear passenger seat
Supercharged VQ37
Body underside
Under engine cover off
Driver instruments
Engine running no warning lights
Dynosheet for 91, 98 and 100 octane maps
clear coat scratches driver door
can't see the scratches at most angles
driver rear door ding
yellowing on headlight and screw hole touch up when bumper re-attached.
sootfoot is offline
Rochester (07-14-2023)
Old 06-28-2023, 03:42 PM
sootfoot
sootfoot's Avatar
Maintenance
It has been a really fun chapter going from practical 4 door daily driver to project car. And, it has been maintained well. Oil changes with factory filters and Mobil 1 or Idemitsu oil every 3k miles or 1 year when it stopped being driven as a commuter. The coolant was done twice once when the CSF radiator went in and again when the radiator hoses were replaced in March 2023. There's fresh Motul brake fluid in the brake lines. I believe it was Redline differential fluid used when that got changed before the transmission upgrade in 2018 at 87k miles. Once the Level 10 trans went in that was filled with Nissan ATF. The power steering also got a top off of new ATF when the two reservoir hoses were replaced in March 2023.
There’s enough fueling on the car for the high 500 low 600hp levels. This could be achieved by having a larger air filter plumbed somewhere in the bumper area and/or running a turbo guard and a E85 tune. I personally felt the car was fast enough even though I put some research into how I would have solved putting a larger air filter in.
Equipment:
A window sticker is provided in the photo gallery, and a partial list of notable equipment includes:
Premium Package (power sunroof, Bose sound system, driver's memory system, driver's power lumbar support, power tilt and telescopic steering wheel, auto-dimming rearview mirror, HomeLink, Bluetooth functionality, one-touch auto-up/down rear windows, heated front seats and side mirrors)
Recent Service History
April 2023: Wiper blades and upper and lower radiator hoses replaced, Z1 Motorsports front brake pads and power steering hoses installed, brake fluid and power steering fluid changed
March 2023: Oil pan resealed, Oil temperature sensor replaced, coolant changed
September 2022: Battery replaced
March 2022: Tires replaced
September 2018: Differential fluid changed
Other Items Included in Sale
2 keys
Owner's manual
Window sticker
Some factory parts including exhaust, catalytic converters, intake manifold, intake, injectors, and suspension
EcuTek OBD Bluetooth map switcher and datalogging tool
2 additional 19x10" Advan Racing RZII rear wheels
Aftermarket 9lb boost pulley and high-flow catalytic converters
sootfoot is offline
socketz67 (07-01-2023)
Old 07-14-2023, 10:19 AM
2010sedanS
2010sedanS's Avatar
Awesome and tastefully modified, GLWS.
2010sedanS is offline
Old 07-14-2023, 11:32 AM
sootfoot
sootfoot's Avatar
Thank you. I've poured a lot of effort, time and money into it.
sootfoot is offline
Misa
08-23-2022 03:18 PM
2009G37XSedan
03-29-2021 06:52 PM
Mattimus
11-29-2020 07:59 AM
indyn
06-27-2016 04:53 PM
Quick Reply: FS 2009 G37S Sedan (AT) Supercharged MotoIQ project car
