WTB Accelerator Pedal and Clockspring
Price: $1234
Location (State/Prov): Can-ON
I am trying to diagnose an issue with my car and would rather take a chance on used parts before paying new prices. If anyone has an accelerator pedal with the sensor as well as a clockspring available please contact me asap. If you have both that is awesome but willing to buy the pieces separately.
Thanks,
Bigwilly
I "might" have my old clockspring (2008 G37 Coupe) from when I swapped everything over to the '18+Q60.... I will have to check my junk cabinet.... no promises, though.
What issue are you having with the clockspring?
The accelerator pedal is the potential issue, I am having the following codes related to throttle/pedal position sensor for both high and low voltage on both banks. I have gone through every wire from the ECU to the TB's including removing the harness from the car and checking for knicks or breaks, all checked out. Checked all the grounds, all good and even added a Stillen grounding kit, still nothing. I have tried swapping TB's to another set, didn't fix it. Finally going to check the pedal because I do not get any change in voltage at the TB harness when the pedal is depressed or released.
I had a TB issue with one of my engine swaps. Broken TB connector, I replaced the connector shell however upon pulling of the wiring by the connector the pins would stop making contact.
Janking on the wiring while being on helped me find it. Pedals can be found on Ebay for $60
Ace_07
Jan 7, 2021 05:30 PM
