FS SPC Rear Camber / Toe Bolts
Old Jul 9, 2019 | 09:19 PM
grocerylist's Avatar
grocerylist
Price: $10
Location (State/Prov): WA
New/Never used SPC Rear Camber / Toe Bolts ($10 + shipping)
The 72265 Rear Kit offers adjustment for the 370Z / G37 / Q60 Coupe. These cams replace the OE camber adjustment cams and provide additional camber (+/- 3.0 degrees) and toe (+/- 3.0 degrees) changes. Adjustment slots will need to be elongated using the 85125 rotary file set or equivalent. This is the perfect kit to adjust rear alignment angles for optimum handling and maximum tire life.
Rear Adjustment range: Camber ±3.00 degree Toe ±3.00 degree
Note: Two kits are required to complete installation if you are using stock arms. (Camber arm and spring perch location)
Only one kit is required if you already have adjustable camber arms other than SPC. (Spring perch location only)
Fits:
  • 2009+ Nissan 370Z (Z34)
  • 2009-2013 Infiniti G37 (V36/CV36)
  • 2014-2015 Infiniti Q60 Coupe (CV36)
Old Aug 26, 2019 | 07:40 AM
mike_engr's Avatar
mike_engr
Hi, I'm actually looking for a single set of OEM Camber Bolt,Washer,Nut. Do u know if your 3-degree kit can be used as is to achieve the standard +/- 2-degrees without having to widen the slot?? If so, would you mind selling just 1? Seems like there should be hundreds of OEM singles laying around but few are selling them and no one is selling them as singles... Need to get these soon before my 6month alignment expires!
bigc
Jan 28, 2018 11:42 PM
xpcgamer
Jun 28, 2016 11:36 AM
VA_55
May 13, 2013 09:43 PM
JDM
Apr 19, 2011 01:58 PM
EVO-to-G
Brakes
Apr 26, 2009 11:18 PM
