Bought this kit for my 2011 g37xs. Installed the front only and sold the car. Still have the rear kit, never installed.
The part number is 72260.
Fits 2008-2013 g37, 2008 g35, 2011-2012 g25, 2014-2017 qx50, 2009-2017 370z, 2014-2017 qx70, 2006-2010 m45 and some others. Fits awd or rwd.
Per SPC's website:
"The 72260 Adjustable Rear Arm for the Infiniti G35 offers maximum adjustment for camber and toe. This is the perfect kit to adjust rear angle for optimum handling and to maximize tire life, adjusts camber ±3.0° and toe ±2.0°. Use the 85130 Rotary File Set to elongate the OE toe slots.
Rear Adjustment range: Camber ±3.0° Toe ±2.0°
Installation time: .7 hr/side
Required: 1 kit per wheel
Recommended Tools: 85130 Rotary File Set
This kit uses a larger cam washer to achieve greater adjustment than the OE toe cam provides. In order to take advantage of full toe adjustment mark the area to elongate the existing toe slot with template provided. Rotary file #85130 Rotary File Set makes this job quick and easy."
