FS Uprev Cable with License
Old Jul 24, 2015 | 11:43 AM
vquezada24's Avatar
vquezada24
Solddddddddddddd
Category: Engine - Power Adders
Price: $1
Location (State/Prov): NY
Soldddddddddddddddddddd
Old Jul 25, 2015 | 02:20 AM
vquezada24's Avatar
vquezada24
bummmmmmmmmmmmp
Old Jul 26, 2015 | 06:58 PM
seymore4's Avatar
seymore4
Just to clarify for any potential buyers this does not include any tuning, whoever purchases it will have to pay for tuning support from either uprev or another protuner. No free tuning is included with used kits
Old Jul 28, 2015 | 12:58 PM
vquezada24's Avatar
vquezada24
correct no free tuning, cable is still required to tune your car by a tuner or you can contact uprev and theyll give you an E-Tune based on your car log and email it to you in about a week for 50$. Also you can still clear codes using the cable with your laptop
Old Jul 28, 2015 | 02:49 PM
seymore4's Avatar
seymore4
No its not; any protuner can sell you a license and tune the car.. you do not "need" the cable. Its nice to have but not necessary.
The $50 etunes are for updates to a tune that they have already done, for example Osiris standard customers who want additional etunes. If you do not have a tune from them you have to purchase a base tune for $250 which includes 3 etune updates.
Osiris - Base Tune
This is true.
Old Jul 28, 2015 | 05:46 PM
kaostheory1's Avatar
kaostheory1
Just to clarify, is this a one and done license or can it be re-used for multiple tunes?
Old Jul 28, 2015 | 06:01 PM
warpeacelove's Avatar
warpeacelove
The cable is required if you're attempting to diagnose your tune or car codes like CELS for an example.
The license is attached to the Flashed ECU but you must have the cable to Flash the ECU.
From there you can Tune your car as Many Times as you'll like as long as your Uprev license is still affiliated with the ECU.
Remember tunes aren't free it must be done by a professional tuner or your can obtain an E-Tune either route still cost.
Old Jul 29, 2015 | 01:37 PM
vquezada24's Avatar
vquezada24
bumnpppppppp. Etunes cost 50$ from uprev
Old Jul 29, 2015 | 05:25 PM
vquezada24's Avatar
vquezada24
bummmmmmmp
Old Jul 30, 2015 | 10:39 AM
kaostheory1
Is this the Standard or Tuner package? Standard does not support FI and is much more limited.
Old Jul 30, 2015 | 12:21 PM
vquezada24's Avatar
vquezada24
standard
Old Jul 30, 2015 | 08:52 PM
stevo4756's Avatar
stevo4756
I don't know about much more limited. If you want to adjust things on your own then buy the tuner. If you are going FI then buy the tuner version.
Otherwise, buy the standard version take it in for dyno tune and save some $$ until you find 5-10k for a turbo setup. I can almost guarantee a dyno tune by a professional will yield better results as well.
Old Jul 30, 2015 | 09:01 PM
stevo4756's Avatar
stevo4756
Parameters that are supported in the ROM Editor include:
• Up to 5 Maps on cruise control equipped vehicles
• Idle RPM
• Speed Limiter
• Electronic Throttle Control to achieve Wide Open Throttle at all speeds.
• Rev Limiter
• DTC disable
• AFR Targets
• Fuel Compensation
• Ignition Timing Advance
• Cam Phasing for equipped vehicles.
• MAF transfer function
• Cranking Enrichment and Ignition Advance
• Injector Latency
• K Fuel Multiplier
• Intake Temp
• Calculated Load vs. RPM
• Minimum Effective Injector Pulse Width
P.s. ROM editor is included in the tuner version. Basically the same thing your dyno / tuner will use to make adjustments. If I'm off course someone please correct me.
Old Aug 1, 2015 | 06:38 PM
vquezada24's Avatar
vquezada24
bummmmmmmmmp
Old Aug 2, 2015 | 11:32 AM
vquezada24's Avatar
vquezada24
bummmmmmmmp
