FS Swift Linear Springs 10k/6k for Stance/BC
Price: $270
Location (State/Prov): TX
It might help if you could list the springs' inside diameter and length in mm for potential buyers to be able to determine if they will fit their coils. Also, are these spring perches for the upper and lower positions in the rear?
So the shorter rear Swift springs when mounted on the lower gold perches come out about the same length as the stock BC rear springs, or are they a bit longer? Just curious since the BCs start out pretty low.
That's a nice spring set, wish I could pull the trigger
GLWS.
GLWS.
I think so just a less aggressive spring rate
no these are linear springs. They replace the BC springs or stance springs that come with the factory kit to provide a different level of spring rate that's more OEM feel and drivability with the dropping the car.
si_driver
Oct 1, 2015 09:53 AM
